farmalls
- Joined
- Mar 22, 2018
- Messages
- 7
- Location
- North Dakota
- Tractor
- JD 50-20s, Farmall A & Bs , 510D backhoe
Hi all I like this site . Probably like most here I finally signed up because I have problems.
My backhoe has always had good power and strong hydraulics with no noticeable lag in shifting. I got out to hook up a chain and got back in and
it wouldn't move but wheels were free. (Park brake had quit working early this winter and I had to put a bigger fuse in or it blows fuse ) I might have 2 problems . Long story short with all tires in the air they will turn in reverse ever so slow in 1st and 2nd gear no matter what position FNR lever is in. On the ground driveshaft will spin in reverse if I give it some throttle then stalls out and spins the other direction and stops. (Like it is relieving a slight pressure that has built up ). But no pull down on the engine whatsoever. Thanks in advance for any ideas where I should start .
