DepthCharge
Hello,
I just put my 410 loader back on my 4115 this morning and I have a strange problem.
Lift and lower works fine and I think bucket tilt up works fine but when I try to dump the bucket I have a problem.
If I try to dump the bucket by pushing the lever all the way to the right the bucker actually tilts up. At the same time you can tell the hydraulics are laboring (with an empty bucket).
If I push the lever just a little right the bucket will dump very slowly and again the hydraulics labor.
If I start with the lever pushed just a little right with the bucket slowly dumping and then push a little more then the bucket will stop dumping (hydraulic laboring still) and then if I push it a little more right the bucket will start to tilt back up.
I have checked the hose connections several times and they are correct. Everything worked fine when the loader was on the tractor a couple weeks ago. There are no obvious mechanical defects on the loader.
I imagine that the transition from dumping to tilt back as I push the lever further right is relarted to the normal transition from standard to regenerative dump.
Anyone have any ideas as to what could be wrong?
