mhalla
Gold Member
<font color="green">Any 2210 owners out there who have experienced at fuel line leak right at the tank?
On Sunday I noticed the smell of raw diesel fuel and after opening the hood and looking around I discovered there was some slight fuel leakage coming from each of the two hoses that connect to the fuel tank. The leakage is through the side of the hoses just above the clamp where each hose takes a 90 degree toward the engine.
I need to take the hood completely off to check it out better so I don't know if a mouse decided to bite into the rubber or the hose couldn't handle the stress of being bent at so sharp an angle. The hose feels rough where the fuel is leaking so based on my sense of touch either cause seems reasonable.
If other 2210 owners are having or have had the same problem where it was a warranty issue with the fuel line I might be able to rule out a mouse being the culprit.
My 2210 is a year and a half old.
Mike</font>
Mike</font>
