Noticed my 4320 leaking transmission oil in front of the rear axle (below the seat area). Crawled under the tractor and found a sensor on the left side of the transmission where the oil seems to be coming from. There is a two pronged wire that looks like it is supposed to plug into the sensor, but was hanging loose.
I guess the first question is what is the purpose of the sensor (temp?). How do I know if it is working or needs to be replaced? Should I just plug the wire back in, tighten it up and see if that stops the leak? Anything I should watch out for as far as torque on this sensor?
Tractor is still under warranty, but if this isn't a big deal, I would rather not hassle with taking it in to the dealer.
Any advice is appreciated.
