Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Join Date
    Dec 2004
    Posts
    140
    Pennsylvania
    JD 3720 Hydro, 850D Gator
    Default 3000 Series Cruise / Speed Match / Motion Match
    I ordered the cruise control for my 3720. It apparently also includes Speed Match and Motion Match (Correct me if I am wrong) My question is do you 3000 series owners that have same use the Speed Match or Motion Match and if so, what applications? Also on the cruise control, does it slow in curves or is it the same speed regardless of grades/ turns/ etc.?
    Thanks Shooter
  2. #2
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    JD 4300, JD X485 JD 4x2 Gator, JD 425, JD455
    Default Re: 3000 Series Cruise / Speed Match / Motion Match
    The cruise control will not slow on curves or hills, same as your car cruise. There is not much of a brain in it, other than to maintain the 'speed'. If you think you should slow down, you will have to supply the brain power and the reaction, I do believe. [img]/forums/images/graemlins/wink.gif[/img]
    Shooter:
    I just read your bio and see you are a State Trooper. Were you pulling our leg on that question about cruise control slowing for curves? I do think you were. [img]/forums/images/graemlins/wink.gif[/img] [img]/forums/images/graemlins/grin.gif[/img]
  3. #3
    Join Date
    Dec 2004
    Posts
    140
    Pennsylvania
    beenthere:
    No BS on this end. A guy I work with has a diesel tractor (small Toro I believe) with cruise control that adjusts for turns. Thought it sounded like a good idea and hoped that JD might do that as well.
    I looked at the 3720 manual and have found that I will just have the standard cruise control (mistake on my part not knowing that a standard cruise was included). For those that have the auto style upgrade with motion and speed match - do you use either much?
    Thanks Shooter
  4. #4
    Join Date
    Jul 2003
    Posts
    140
    My experience has been mostly on the now being phased out Ten Series, but the Cruise/Speed Match/Motion Match option appears to be unchanged. I have played with Speed Match and can imagine it being useful for somebody, but not for me. I usually kept the Motion Match switch set for the more aggressive setting, but now and then found the less aggressive setting more suitable, particularly when doing work on turf where it helped reduce tire skidding.
    The most useful of the features for me has been the Automotive cruise. When using cruise it allows you to "resume" or return to the previously set speed after slowing or stopping. It also has a +/- switch that lets you speed up or slow down in stepped increments, similar to your car. With the standard cruise you have to find your speed and set it again everytime after slowing or stopping.
    My experience is that the cruise maintains the speed exceptionally well as long as the engine isn't overloaded. When Load Match is turned on, it will slow the tractor to prevent the engine speed from dropping too much, even if cruise is set. I have used this combination while mowing and even once while running a snow blower and it works great. Just set cruise at the highest speed you want to travel, then Load Match will automatically slow the ground speed as taller grass (or deeper snow) is encountered and return to speed as the load lightens.
  5. #5
    Join Date
    Jun 2004
    Posts
    743
    John Deere 3320
    Can I bring this topic up again please?
    So what does the 3X20 series come with standard? I know cruise button on left and I-match on left side of colum. Does it come with motion match? If so how do you use/set it.
    IS the $86 upgrade to automotive worth it to get the extra buttons or do you have it already?? Manual says Def is on the display for motion match when you have ehydro and no extra buttons.
    I am a bit confused on all of these three options.
  6. #6
    Gold Member
    Join Date
    Jul 2005
    Posts
    257
    saint leonard , MD
    John Deere 4320
    The button on the left of the colum is load match and it comes standard. I match is a hitch bracket that mounts to your 3 point hitch , for easy equipment atachment. I hope this helps.
    Jim
  7. #7
    Elite Member rockyridgefarm's Avatar
    Join Date
    Mar 2002
    Posts
    4,454
    Road 4310
    Deere 4310 HST MFWD
    The upgrades add functionality and make the existing features easier to use. They are well worth the money, especially if you need an item for a Christmas or Birthday idea from those poor shoppers who have been stuck buying neckties... (but i like thies, just humor here...)
    All you get for $86 is a switch and a little pigtail. But the added value is what really matters...
  8. #8
    Join Date
    Jun 2004
    Posts
    743
    John Deere 3320
    I guess I meant Load match not I-Match [img]/forums/images/graemlins/smile.gif[/img]
    So - the questions I still have can I use all the functions without the controls on the right side?
    Can I install the switch plate myself at a latter time? Does it come with the two extra switches?
  9. #9
    Join Date
    Mar 2002
    Posts
    4,454
    Road 4310
    Deere 4310 HST MFWD
    The switches make using MotionMatch easier. They add upgraded cruise control (resume like a car's) You can easily install them yourself, the hardest part is cutting the plastic. ( there is an outline, a die grinder or mototool does a good job..)
    If you order them with the tracor the labor might get thrown in...
  10. #10
    Join Date
    Jun 2004
    Posts
    743
    John Deere 3320
    So is there specific funtctionality to set the rate of deceleration for motion match with the upgraded buttons?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
