Results 1 to 3 of 3
  1. #1
    Gold Member
    Join Date
    Jan 2005
    Posts
    288
    new london county,ct
    jd h, jd 50, jd2010,jd 790,case530hoe
    Default 790 5hr review
    i got my 790 last fri. first off i love this machine, loads of power. the gearing seems to fit it well also. i did some grading w/ the 300 loader and it works great esp the float position,loads better than the old case 530bh that i'm used to using. i also pushed over and moved some old wild rose bushes but i need to spray them w/ something to do the rest. i don't have filled tires but think i may fill them plus add a bit more weight to the ballast box for fel work, it seemed to run out of traction fairly easy. i then did some bushhogging w/ the lx5. the old pasture area had grass as high as the rear tires and very thick in spots, the tractor didn't even flinch, i did however go pretty slow just to be safe and get a feel for the new tractor. i wacked 1 rock no damage thankfully.my one complaint would be i kept bumping the loader control while looking back, it seems like this is common on most of the cuts w/ loader control on the platform. my dad came by to check it out while i was doing the mowing and he had to give it a try, it was hard to get him off it, so i only got to mow about 1/4 of the pasture. he likes that 790 very much, i can see him coming by to take it back to the farm for himself. it also got him thinking about a newer machine. today i will try tedding some hay and then later in the week raking. we only have a 2 spindle tedder so there should be no hp issues, and the old nh side delivery rake is ground drive. all in all i'm very impressed w/ this tractor and glad i did buy it. being a gear model is no big deal for me, as thats all i ever used except for my lawn mower which is hydro.
  2. #2
    Veteran Member JDFANATIC's Avatar
    Join Date
    Jun 2004
    Posts
    1,346
    Central Connecticut
    JD 2210
    Default Re: 790 5hr review
    farmerjim,
    Congrats on your purchase! And WOW! A post after just 5 hrs! Talk about guidiness! [img]/forums/images/graemlins/grin.gif[/img]
    P.S. I know the feeling! [img]/forums/images/graemlins/cool.gif[/img]
  3. #3
    Join Date
    Dec 2004
    Posts
    303
    Amelia Va.
    John Deere 790wFEL
    Glad your enjoying it. As far as bumping the loader control..... on mine it would be the dump function and you can lock that out , you would still be able to raise and lower the loader, but not dump or curl .This would work when your not doing loader work. Also try taking the bucket off while cutting, it improves visibility and only takes a second to release. Have fun and rack up some hours on that thing !!!!!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
