Results 1 to 2 of 2
  1. #1
    Join Date
    Apr 2005
    Posts
    133
    New Hampshire, USA
    JD 4500
    Default JD 4500 Power Beyond Question with Impliments
    I have a 4500 operating a Kuhn 6' flailmower. This mower comes equipt with an optional hydraulic offset for those places where the tractor won't fit or too close to a fence, wall, etc... If I connect my power beyond to it I lose my 3 pth capability and it will not lift. Obviously i am overlooking something simple. All advise will be appreciated. Thanks, Roger
  2. #2
    Elite Member rockyridgefarm's Avatar
    Join Date
    Mar 2002
    Posts
    4,689
    Oklahoma's Green Country
    Yanmar YT347
    Default Re: JD 4500 Power Beyond Question with Impliments
    No, not power beyond! As you see, it doesn't work, and that isn't what its for... Power beyond is used to connect a backhoe, or splitter; something with its own selective control valves (SCV's)
    If you dont already have it, what you need is a third SCV. (See attached pic...) There will be another set of outlets in the rear and a 1 way stick in front of your cupholder
    AM875172 SV (A-1) ****'Y $568.24** USD (should be it, but I am NOT a parts guy, although I DO play one on television...) [ [img]/forums/images/graemlins/shocked.gif[/img]that's Assembly, it's not often that I get edited! [img]/forums/images/graemlins/shocked.gif[/img]]
    ** hey, its only money! what else would you possibly do with it anyway?!!!
    You can also get an aftermarket valve. It won't be as clean. You already have the valve, you just need the control and plumbing...
    Attached Images Attached Images
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
