Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,926
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Default Re: NorthStar PTO generator
    </font><font color="blue" class="small">( I paid $625.00 for a new 10K leroy
    sommer gen head with gearbox and $75.00 for the pto bar.
    )</font>
    Where did you get this deal from?
  2. #12
    Join Date
    Jan 2004
    Posts
    52
    JD 2210
    To answer the original question on why some PTO generators must be trailer mounted: It depends on the size and hence starting torque required by the generator. Large PTO generators require more starting torque and when they are lifted off of the ground they put twisting force on the 3ph. That is obviously different from the implement resting on the ground requiring a lot of starting torque. The 3ph was not designed for that kind of twisting force. However for smaller PTO generators, there is really no issue.
  3. #13
    Join Date
    Jan 2004
    Posts
    52
    JD 2210
    Here is the unit mounted to a carry-all. I put some small casters on it to make it easier/faster to mount. Plus, I put a couple of 2x4's across the underside of the plywood to give the 5/8 inch mounting bolts something rigid to bolt to. Runs like a champ. The tractor needs to run at around 2700 RPM to bring the generator up to the correct voltage (120).
    Attached Images Attached Images
  4. #14
    Join Date
    Dec 2004
    Posts
    19
    check out www.generaljims.com
    look under generators then go to gas generators.
    They have raised the price to 795.00 since I bought mine
    this spring. These are just the gen head and pto gearbox.
    You have to come up with your own mount as well as an
    electrical panel with plugs and circuit breakers. After I built
    my own panel and dumped about $70 bucks in plugs, a panel
    box and breakers I found out surpluscenter.com had a variaty
    of pre made generator panels for dirt cheap.
  5. #15
    Elite Member SkyPup's Avatar
    Join Date
    Dec 2003
    Posts
    3,005
    North Central, Florida
    Kubota L-39 GST TLB, Kubota L3130GST, Massey 1030 HST, Kubota ZD-21 ProDecK, Two Euro VW TDIs
    I have the larger Northern Tool 12kW unit mounted onto a two wheel trailer, it works great and @ 544rpm rear PTO (kubota L-3130 real time PTO tachometer) she puts out 50 amps of 240V or 100 amps of 120V @ 60 hertz.
  6. #16
    New Member
    Join Date
    Oct 2012
    Posts
    12
    West Union, SC
    Ford 1710, New Holland TC29, Long Landtrac 470
    Quote Originally Posted by jdepetri2210 View Post
    So...if the gen head produces too much torque for the 3ph, that's a LOT of torque. Think how much torque it must take to turn a 6' rotor tiller, for example, or an 8' bush hog. So if a gen head needs more torque to start it, what keeps it from flipping a little trailer over when you engage the PTO?
  7. #17
    Join Date
    Mar 2012
    Posts
    505
    Right coast of, GA
    Kubota 1860->25D, MX5800
    Holy thread revival
  8. #18
    Elite Member Sawyer Rob's Avatar
    Join Date
    Dec 2014
    Posts
    3,325
    Upper Mid West
    several brands
    Quote Originally Posted by thescubasmith View Post
    I've seen in happen, because the trailer axle wasn't wide enough for that size gen set... But the gen set was already running, it just had enough load on it to lift one side of the narrow trailer.
    Once a wider axle was put under the trailer, it never happen again...
    SR
  9. #19
    Elite Member Dutch445's Avatar
    Join Date
    Aug 2001
    Posts
    2,633
    Upstate NY
    JD X585
    just a 10 year nap!
    Quote Originally Posted by sea2summit View Post
    Holy thread revival
    JD X585 with 45 loader, 3ph, 62C deck, 47SB, 54 blade, Soft Cab. JD F620 with 60". JD HPX gator. JD T23 trimmer
    JD CS56 and CS36 saws. JS35 WB mower.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
