Broken bucket tab on 300CX loader
   / Broken bucket tab on 300CX loader #1
HuskerInVA
Loudoun County VA
JD 3520, '71 Case 580CK TLB
When I was reattaching my bucket after mowing last night I found that I had broken off one of my bucket attachment tabs. I run with the loader low for stability and visibility. I have occasionally brushed the ground when coming off or heading up my slope. I don't even remember hitting yesterday.
Anyone else have this happen? Possibility of a defect or poor design? See the attached pictures. The metal on the tab is VERY thin. Where it broke, the thickness is about 1/2 the diameter of the attachment pin hole.
I'll call the dealer today and see if I can get it handled under warrantee, but I'm not planing on running without the bucket attached any more. Guess I may have to invest in some front weights and take off the entire loader.
Pic 2
Pic 3
   / Broken bucket tab on 300CX loader #4
Wow! Bad news!
I have heard these things breaking before, because on the new "X" series loaders the entire Quick-Attach bracket is now a casting rather than built-up and welded. I think this was a very poor design on JD's part. Hopefully you can get this replaced under warrenty.
   / Broken bucket tab on 300CX loader #5
Unfortunately that part of the loader is cast steel which is fairly brittle . I wish that part was made from bar or plate. It would have bent instead of braking. All the X and CX loaders are now cast in some areas to save money.
/forums/images/graemlins/frown.gif
Jim
   / Broken bucket tab on 300CX loader #6
i always mowed with the bucket off my 210 loader and hit more than one oak tree. only damage was to the oak tree and my ego. /forums/images/graemlins/crazy.gif
   / Broken bucket tab on 300CX loader #7
Here is a POST I found after searching a little. I sure think this is going to haunt JD and owners after warrenty periods are over... /forums/images/graemlins/mad.gif
   / Broken bucket tab on 300CX loader #8
I have an MX6 on a 4310 - you do the math.. I NEVER mow without the bucket on my 430 loader, and have hit things plenty of times. It never even occured to me that the koader wasn't up to this (and I still doubt there is any problem with mine...) I sure hope this gets resolved! Yikes!
I never thought I'd be one of those cantankerous old timers that liked the old stuff better... So this is what it feels like...
   / Broken bucket tab on 300CX loader #9
I had a similar situation happen with my 300CX loader. The tab on the right side broke. I took pictures to show the dealer - what I found was rust INSIDE the break. It looks like you might have the newer casting, but mine was welded and broke on the weld.
Thankfully, I have a great dealer. They came out tha evening (at 7:30 after closing time). Took one look at it and said, yes, this has been a problem with others and we'll fix it. They got the part and sent a mechanic to the farm and replaced it. No charge at all to me.
Not sure how Deere handled it, but my dealer did the right thing.
I was hoping the problem was cured, until I saw your post.
   / Broken bucket tab on 300CX loader #10
There has been a Deere Tech update regarding these parts breaking, stating that production was changed and newer parts are 50% stronger. They state that if 1 side breaks, both sides are to be replaced. Let us know if the dealer doesn't have this info.. and I can give you the case number.
good luck
/forums/images/graemlins/cool.gif
2012 CATERPILLAR 308E CR EXCAVATOR (A52707)
2012 CATERPILLAR...
2019 Doosan LCV6W Towable LED Light Tower (A55851)
2019 Doosan LCV6W...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
2023 Kubota KX057-5 Compact Excavator (A55315)
2023 Kubota...
UNUSED FUTURE 16" AUGER (A57193)
UNUSED FUTURE 16"...
UNUSED I/A R2424 9' OFF SET DISC HARROW (A57192)
UNUSED I/A R2424...
