Results 1 to 9 of 9
  1. #1
    Join Date
    Jan 2006
    Posts
    13
    North Carolina
    Default 3720 operating question, detaching FEL
    My dealer demonstrated way to detach FEL. He put the bucket flat on the level concrete and inched it forward to bring the loader support arms up/off their mounting posts on the body of the tractor. Doing this seems to scar up the bottom of the bucket surface quite a bit. I have been taught, previously, to roll up the bucket fully, and to use the pivot point underneath in contact with the ground, as the FEL is moved forward, off its mounts. which is the correct way? does it matter?
  2. #2
    Elite Member Dutch445's Avatar
    Join Date
    Aug 2001
    Posts
    2,511
    Upstate NY
    JD X585
    Default Re: 3720 operating question, detaching FEL
    Here is a link to a video Deere has on their website that shows the removal and installation of the loader.
    loader demo video
    I think the best way would be as they do in the video, with the bucket flat on the ground. You also want to be able to eliminate any pressure in the lines so your couplers work easier.
    [img]/forums/images/graemlins/cool.gif[/img]
  3. #3
    Veteran Member JDFANATIC's Avatar
    Join Date
    Jun 2004
    Posts
    1,346
    Central Connecticut
    JD 2210
    Dutch, good video.
    buckie, in my experience with the new buckets you will either want to roll the bucket back slightly to the second flat or go all the way to full dump and past. The reason for this, is if you do it the way shown in the video, the bucket will curl back naturally over time. This will cause pressure to build up in the hoses and you won't be able to connect them without "bleeding" them by putting the heads in a rag and pressing or banging them against something. My old 755 never had this problem, but the bucket design then was different. If you roll the bucket back slightly, the disadvantage is that water will accumulate in it, if you store in the full dump + position, this won't happen.
    [img]/forums/images/graemlins/tongue.gif[/img]
  4. #4
    Join Date
    Jul 2003
    Posts
    560
    Baldwinsville, NY (10 miles NW of Syracuse)
    JD 4310, ehydro, 4WD, R4s
    <font color="blue"> If you roll the bucket back slightly, the disadvantage is that water will accumulate in it, if you store in the full dump + position, this won't happen.
    </font>
    But your hyraulic cylinder rods will be exposed and subject to corrosion followed by leaking seals. I would rather have the water accumulate in the bucket.
    Jeff
  5. #5
    Join Date
    Jul 2003
    Posts
    560
    Dutch,
    Nice video. But why does that orange tractor have a green ballast box and why does the guy always take the long way around the tractor? It seems like the shortest way back to the seat is around the back of the tractor. It just seems like he could have done more to keep up with the Deere [img]/forums/images/graemlins/grin.gif[/img]
    Jeff
  6. #6
    Join Date
    Aug 2001
    Posts
    2,511
    Upstate NY
    JD X585
    that's probably what you would call propaganda...
  7. #7
    Gold Member
    Join Date
    Oct 2000
    Posts
    412
    NH
    John Deere 3720 Cab Tractor
    I wouldn't call it Propaganda, I watched this video twice to make sure both men take the same route each time they get on and off the tractor. It looks realistic to me. The only thing I would have done different is climb up on the closest side of the machine, although it is tight, squeezing through is easier than walking the whole way around. But both men took the same route each time they had to get on and off their tractor. So it looks fair. John Deere Loaders come off faster and easier.
  8. #8
    Join Date
    Jan 2006
    Posts
    91
    IN
    '06 3520, '09 997 ZTR
    Hi, Buckie,
    As the hydraulics are detaching the FEL, I slowly back
    the tractor out instead of letting the bucket get pushed forward.
    So, as the loader wants to move away (forward), I back the tractor
    up instead. Takes some practice, but where you drop the bucket
    is where it stays (plus or minus a couple of inches). Moving
    slowly is the key.
    The inverse when attaching the loader - you want to drive the
    tractor forward - very slowly as the arms move downward.
    I know it's a poor explanation, but hopefully it conveys
    the idea.
    I got tired of trying to place in the garage where I wanted the
    loader to sit and then when detaching it, it always moved and
    ended up a good foot or more from where I wanted it. This is
    okay if you're outdoors, but not in the garage. AND definitely
    not on an epoxy - urethane floor. I put a sheet of plexiglas
    under the bucket and the arms to keep from messing up
    the floor.
    Cheers,
    Lon
    Remember: The sky is Carolina blue.
  9. #9
    Join Date
    Jun 2004
    Posts
    746
    John Deere 3320
    I have a 72" Front snow blade. Can I detach the loader with that on? I think I read only to detach with the standard materials bucket on. Anyone have experience detaching with other attachments on?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
