Results 1 to 6 of 6
  1. #1
    Join Date
    Jan 2006
    Posts
    133
    Southwest Ontario, Canada
    JD 2520
    Default Rear Work Light
    I mounted the rear work light using the bolts that hold the Tail light.
    I run this light with an Aux power wire that I had the dealer install for use with my electric JD sprayer.
    It is useful for alot of things. The power switch is on the dash next to the Cruise Control and PTO switch. When I use the sprayer I have to unplug the light temporarily.
    Attached Images Attached Images
  2. #2
    Join Date
    Jan 2006
    Posts
    133
    JD 2520
    Default Re: Rear Work Light
    Rear Light...
  3. #3
    Member
    Join Date
    Jun 2005
    Posts
    40
    Tewksbury Twsp., NJ
    JD 2305
    Is that at JD light switch and if so, what model #? I went to my dealer today looking for that switch, but it turned into a goose chase and was unable to find it.
  4. #4
    Join Date
    Nov 2004
    Posts
    120
    Smyrna,Delaware
    JD 4520
    The switch is used on the Gators,headlight off/on .The p/n is AM117324 it cost me $7.28 back in 2/7/05
    Mike
  5. #5
    Silver Member JD3520's Avatar
    Join Date
    Aug 2005
    Posts
    122
    TEXAS
    JD 3520
    The price for the JD Gator switch is now $10.75 in the DFW, Texas area. I paid $9.00 for mine in Oct 2005. At a boat supply place you can get a switch for around $6.00 if your JD dealer can't locate one. It is just as good if not better and will be rated for outdoor use. I bought the Gator switch because I wanted my tractor to be "all John Deere".
    chuck
  6. #6
    Join Date
    Jan 2006
    Posts
    133
    JD 2520
    Hi,
    I got the switch at my dealer and dont know the part # as he threw it in and I dont have the box anymore.
    I do know for sure that it is the same switch that my JD 445 had as a light switch.
    I like to keep everything looking JD original.
    Thanks...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
