Results 1 to 7 of 7
  1. #1
    Join Date
    Apr 2004
    Posts
    1,125
    Michigan
    Deere 3720 Cab eHydro , JD 455AWS, JD X749AWS, JD 2720, 2015 Toolcat, Bobcat E42 Excavator, BRP Maverick Max, JD 2038R
    Default 2305 - Lift & Curl?
    I used my 2305 with the FEL this weekend for the first time and noticed I could not lift and curl the bucket at the same time, is this normal?
  2. #2
    Elite Member
    Rest in Peace
    Join Date
    Apr 2003
    Posts
    3,741
    New Hampshire
    Kubota B2710, IH TD6-62 dozer with Drott 4n1 bucket loader
    Default Re: 2305 - Lift & Curl?
    Absolutely normal.
    You are trying to perform 2 functions whereby each has to use hydraulic pressure to overcome the load (and gravity). Do to the design of most valves one function/spool will have priority for fluid flow while the others will get what is left over, if any.
    Other combinations of functions work because gravity is available to help with the one function that does not get enough fluid. For example dump/lift, curl/lower, dump/lower.
    I hope I have made that clear.
  3. #3
    Join Date
    Nov 2005
    Posts
    158
    Stanwood, MI
    JD 3320, JD GT235, JD 116, JD 57, an several other makes of lawntractors somewhere around 8 of them
    Hey Robert, my 3320 is the same way. I've read here on tbn that it's due to the "cheaper" control valve that deere uses. I mentioned this to the mechanic that Voelkers sent down to check my hydro pressures and he said that yes you can do two functions at the same time, you just have to have the knack for it, I told him to show me: He tried to show me but wasn't any better at it than I was. Yes you can do two functions at the same time, but you have to have the lever in exactly the right spot to do it, after trying several times I've come to the conclusion that it's just a whole lot easier to just do one thing at a time and forget about it. I suppose that after I get used to running it and have the desire, I'll catch on to doing two functions at a time. But in my opinion it's one of those things that are a glitch in the deere that I can live with because the rest of the tractor more than makes up for it. By the way, you should see how much better my fel and 3pt works now that the pressure relief has been adjusted WOW what a difference. I've found that the fel has alot more break out force, and just for s*#ts and grins I picked up the front of an old pickup truck that the brakes were seized up on to put jack stands under it, the fel didn't even care. I picked it up without even raising the throttle up past idle. I was impressed! Have a good week Robert!
    Larry
    p.s. I can't wait to get the backhoe on to try it out with the added hydro pressure. Others here on tbn with a backhoe should look into having their pressure's checked
  4. #4
    Join Date
    Jul 2005
    Posts
    61
    SW Missouri
    Sounds like you have the same issue I have with the 3320's;
    3320 won't lift and dump
    Good Luck!
  5. #5
    Join Date
    Jan 2006
    Posts
    108
    Central NY
    2006 JD 2305
    </font><font color="blue" class="small">( I used my 2305 with the FEL this weekend for the first time and noticed I could not lift and curl the bucket at the same time, is this normal? )</font>
    No, my 2305 works as it should. Make sure you have the engine to at least pto speed, and move the joystick slowly until you get used to it. Understand that the combined functions may be a little slower than either function would be independently.
  6. #6
    Join Date
    Dec 2005
    Posts
    100
    North Carolina
    JD 2305
    I also can lift and curl the bucket on my 2305, you just have to find that right spot. It is however easier to just do one function at a time.
  7. #7
    Join Date
    Apr 2004
    Posts
    1,125
    Michigan
    Thanks all. I will go try it again maybe I can find the touch.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
