Results 1 to 6 of 6
  1. #1
    Join Date
    Feb 2005
    Posts
    69
    NC
    John Deere LX280 John Deere 790 4wd with 300 loader
    Default 790 gauges quit working
    Have noticed the last few times I have been on my tractor the gauges are slow to respond. They may take as long as 5 minutes to start working or sometimes they come as they should when I turn the switch. But today they didnt do nothing I turned the tractor off and tried it again. Anybody had this problem on the 790?
  2. #2
    Join Date
    May 2001
    Posts
    670
    Ontario, NY
    JD 790 (2001)
    Default Re: 790 gauges quit working
    Sounds to me that the power supply TO the gadgets that are doing the measurements is failing.
    Start there and check fuses.
  3. #3
    Join Date
    Jun 2003
    Posts
    206
    Northwest MO
    Allis D17 CIH D40, JD5310, Massimo MS50010
    My 870 JD does the same thing, I'm thinking a bad ground somewhere but can't find it.
  4. #4
    Join Date
    Feb 2005
    Posts
    69
    NC
    I thought that I might have found the problem with the battery. The ground terminal was real loose. Tightened it didnt help. Will check the fuses tommorow hope I find the problem there.
  5. #5
    Join Date
    Feb 2005
    Posts
    69
    NC
    Checked all the fuses no problem there. Checked all the connections they looked good. Will take dash cover off to check inside next. Do not understand why sometimes they work and sometimes they dont.
  6. #6
    Join Date
    Dec 2005
    Posts
    8
    I have a 3320 with electronic guages, your problen sounds very much like a loose wire. componet or fuse failure they will not come back. If they are all doing the same thing look for something common , that is usually the ground or return side. Be sure to check the fuses are tight in the fuse holder. Turn the key on and start gently messing with the wire harness and connections. Could be something in the harness you can not see directly but if it is you will see it when you start moving things around
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
