Results 1 to 5 of 5
  1. #1
    New Member U2DEERE's Avatar
    Join Date
    Mar 2006
    Posts
    10
    Default 4200 Collar Shift Differential Lock
    Has anyone had any experience with the differential lock failing. The model is a 4200 collar shift. Is it a simple fix or a larger problem?
  2. #2
    Join Date
    Feb 2006
    Posts
    178
    Default Re: 4200 Collar Shift Differential Lock
    We haven't had any problems with the Diff Lock, but have had some problems with the Collar Shifts (it was discontiued a few years ago)-is the linkage hooked up? Has the "feel" of the pedal changed? Did it work properly before? When are you engaging it? Do the Brakes and other Controls work properly?
  3. #3
    Join Date
    Mar 2006
    Posts
    10
    I have had no issues with the collar shift when following the manual when shifting (waiting the five seconds between shifts). The tractor is a one owner and has less then 200 hours on it.
    The feel of the differential lock pedal is different. I was using it two weeks ago plowing snow and noticed that when I finished the driveway that it was no longer working. All other things are working proper. There is no linkage just the pedal that attaches directly to the transmission case.
    I am hoping for something like a shear pin or something easy.
  4. #4
    Join Date
    Feb 2006
    Posts
    178
    Probably not good news-maybe that linkage inside has become disconnected or worse-I would suggest you call your Dealer and let him have a look-sorry-
  5. #5
    Join Date
    Jan 2006
    Posts
    80
    Southern NH, USA
    JD 3520
    I'd make that call sooner rather than later because if something inside the cases has come loose or broken, you don't want it getting caught up in the other gears and causing one very expensive repair job!
    BILL
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
