Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Gold Member gunmaker's Avatar
    Join Date
    Apr 2006
    Posts
    286
    nw nj
    jd 425 / jd 2520
    Default 200cx loader
    Does the bucket on the 200cx detach from the frame, to allow other implements to be used in its' place, ie;pallet forks?
  2. #2
    Gold Member davkir's Avatar
    Join Date
    Sep 2005
    Posts
    352
    Hendricks Co., In
    JD 2305 W/CC & R4
    Default Re: 200cx loader
    Yes, picture of pallet forks on 200CX loader attached.
    Attached Images Attached Images
  3. #3
    Join Date
    Apr 2006
    Posts
    286
    nw nj
    jd 425 / jd 2520
    Thanks, the closer I get to putting my money down, the more questions I seem to have.
  4. #4
    Member
    Join Date
    Oct 2005
    Posts
    26
    Michigan
    JD 2305
    Davkir
    How much can you lift with these forks with the 200cx loader? I looked at JD set up but was concerned about the weight of the forks and what would be left to lift a load? What tractor do you have these on?
  5. #5
    Join Date
    Apr 2006
    Posts
    286
    nw nj
    jd 425 / jd 2520
    JD says approx 800+/- on a 2520 w/fel. Are the pallet forks an even weight exchange for the bucket?
  6. #6
    Join Date
    Sep 2005
    Posts
    352
    Hendricks Co., In
    JD 2305 W/CC & R4
    I don't know how much it will lift, but I think the pallet forks are about 250 lbs. compared to the J.D. ones which I think are more like 400.
    If you use a lot of ballast, my 2305 will lift quite a bit. I move my dumpster around when it is empty or has lightweight stuff like hay in it. Pallets with 10 bales of hay, stacks of rubber horse mats, landscaping material...they're pretty handy.
    I will TRY to attach a couple of pictures.
  7. #7
    Join Date
    Sep 2005
    Posts
    352
    Hendricks Co., In
    JD 2305 W/CC & R4
    This is the dumpster I move around.
  8. #8
    Gold Member
    Join Date
    Mar 2005
    Posts
    267
    Looks like your getting a ton of use from the forks [img]/forums/images/graemlins/smile.gif[/img]
  9. #9
    Join Date
    Apr 2006
    Posts
    286
    nw nj
    jd 425 / jd 2520
    Do you think that you could lift a reasonable load (palleted) from the back of a semi, or straight job? [img]/forums/images/graemlins/shocked.gif[/img]
  10. #10
    Join Date
    Sep 2005
    Posts
    352
    Hendricks Co., In
    JD 2305 W/CC & R4
    Well, this is just an opinion, but I would be much more carefull if I were trying to lift near the maximum weight with the forks up very high in the air. If you lift too much close to the ground the tractor will "tell" you and if you keep your hand on the control, you can react quickly.
    I probably wouldn't try to lift more then 400 or 500 lbs. off of a truck even with a lot of ballast.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
