JD 72\" Mid Mower Issue
Wondering if anyone can help figure out what I'm missing or doing wrong. I have a 2520 with the 72" mid mower deck (3pt hitch height controlled).
1. Is there a slick way to lock this mower in the up/transport position so you can use a rear implement without removing the mower each time?
2. When you do remove the mower how do you keep the two lift arms (linkages) from dragging on the ground? It's a pain if you have to remove these with the mower deck each time.
Thanks for the help.
