Page 1 of 3 123 LastLast
Results 1 to 10 of 29
  1. #1
    Join Date
    Mar 2004
    Posts
    131
    Manitoba Canada
    2010 John Deere 2520, John Deere 185, John Deere 155
    Default 2305 PTO noise
    Just had my new 2305 delivered last week. When I put the mower in gear there is two distinct sound. One is the sound of the mower and the other is a higher pitched noise from the rear of the tractor. This noise is not coming from the mower but is only made when the PTO is under load. It almost sounds as if it is a bad bearing. This noise can be heard above the sound of the mower. The dealer sent out a mechanic that did not know much about this tractor. He said the trans fluid was about two cups low which he added and spilled a third one and made no attempt to clean it up. When he was here I was not home and he said he heard no noise. He came back the next day when I was home and all of a sudden he could hear the noise, but did not know what it was. He said they would pick it up and take it into the shop because they have all kinds of gauges to test for noises like that.
    I really don't think he knew what he was talking about.
    I was wondering if anyone with a 2305 and 62" mower
    have heard a simular noise?
  2. #2
    Join Date
    Mar 2004
    Posts
    131
    Manitoba Canada
  3. #3
    Join Date
    Dec 2005
    Posts
    53
    Barneveld. Wisconsin
    2305/345GX
    Default Re: 2305 PTO noise
    I'm not sure, but it seems like its the hydraulic whine is resonating through the ROPS. Kind of like flying in a Army chopper or DC131 cargo plane. There is nothing insulating the noise of all the hydraulics running through the aircraft. Not that I want to repel from my 2305, but the sound does take me back to my service days. I'm sure the low fluid didn't help either. Fitz [img]/forums/images/graemlins/grin.gif[/img]
  4. #4
    Join Date
    Dec 2005
    Posts
    53
    2305/345GX
  5. #5
    Join Date
    Mar 2004
    Posts
    131
    Manitoba Canada
    Hi Fitz So are you saying your 2305 makes this noise also? If so is it as loud or louder than the sound of the mower? My sound is coming from behind and below me. Anyone else have this noise?
  6. #6
    Join Date
    Mar 2004
    Posts
    131
    Manitoba Canada
  7. #7
    Silver Member Piedmont's Avatar
    Join Date
    Mar 2006
    Posts
    173
    NC, USA
    JD 2520
    I have the same set up but no noise. I'm interested in hearing what the dealer has to say.
    There is a PTO guard on the rear PTO and if you had both the mid and rear PTO engaged the noise may be coming from that just a thought.
  8. #8
    Join Date
    Mar 2006
    Posts
    173
    NC, USA
    JD 2520
  9. #9
    Platinum Member chipsndust's Avatar
    Join Date
    Mar 2006
    Posts
    517
    central NY and Adirondacks
    JD 1025R, Curtis cab
    I agree with Piedmont. I have the same equipment, but don't have the noise. You can select mid, rear, or mid and rear PTO. Do you have both engaged?
  10. #10
    Join Date
    Mar 2006
    Posts
    517
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
