Results 1 to 4 of 4
07-17-2006, 09:57 AM #1Member
- Join Date
- Apr 2005
- Posts
- 26
- Location
- Southern Indiana
- Tractor
- 2004 4310
4310 won't move
My 84-hour 4310 w/e-powerreverser started right up, moved about 4 feet forward and stopped with error code 5-3. Same error forward or reverse. Error code "reset" by moving FNR lever to neutral,and is reset without pushing the clutch. With FNR lever in F or R, as I release the clutch AS SOON AS I MOVE IT FROM FULLY DEPRESSED the tractor will lurch forward/backward, as if the potentiometer on the clutch pedal is defective. Funny thing is, my service manual is supposed to be in the dealers parts room today. Any ideas before I go tearing into it?
07-17-2006, 01:14 PM #2Super Star Member
- Join Date
- Feb 2001
- Posts
- 18,747
- Location
- Texas - Wise County - Sunset
- Tractor
- NHTC45D, NH LB75B, Ford Jubilee
Re: 4310 won't move
With only 84 hours, surely you have lots of warranty left. I would not go "tearing into" something unless I knew it would be a simple fix. I'd be on the telephone to my dealer's service dept. If they could not tell me something to check, my tractor would be on its way back for service.
I'm speaking from experience here. On my new tractor, I fixed what should have been done as a warranty repair. It turned out to be twice the job I had estimated and I knew exactly what was wrong (broken weld) before I started. Do what you "must," but consider what you might be getting into before you tackle this problem.Jim
07-17-2006, 01:37 PM #3Veteran Member
- Join Date
- Mar 2004
- Posts
- 2,427
- Location
- Central Ma.
- Tractor
- 7275 Cub Cadet
Re: 4310 won't move
Listen to the Jinman. If you have a warranty, DO NOT mess with the tractor. Let the dealer fix it. Once you try to fix it. You may very well own it.
Cub Cadet 7275, FEL, RFD2584 mower, Box Blade, Scaper Blade, York Rake, Snowblower, Rototiller, Stump grinder, Wood Chipper and a Post Hole Digger.
07-18-2006, 10:30 AM #4Member
- Join Date
- Apr 2005
- Posts
- 26
- Location
- Southern Indiana
- Tractor
- 2004 4310
Re: 4310 won't move
Excellent points regarding the warranty, thank you. I was convinced it was something simple. Last night I looked for "obvious" problems, pulled connectors, chewed-up wires, everything is connected and nothing jumped out at me as being "broke". I will call the dealer today.
