Results 1 to 6 of 6
  1. #1
    Join Date
    Feb 2006
    Posts
    64
    Upstate NY
    JD 4044R
    Default 3520 Radiator Issue
    I have 10 hours on my new 3520 and I have a radiator issue but Iím not sure what is causing it. Since Iíve owned the machine I always have a small puddle of coolant on my concrete floor after using it. I noticed the recovery tank has been below the FULL COLD line when the engine is cold. So I assumed I just needed to add some coolant to the tank. I hadnít added this coolant yet and todayÖafter simply moving the tractor from one place to anotherÖI had a large puddle of coolant on the floor.
    I waited for the engine to cool completely and then checked the radiator level; it was full to the top. The recovery tank level is down to about ľ inch. I crawled under the tractor to feel around for where the coolant was coming from. I saw a few drops at the end of the overflow tubing connected to the recovery tank cap but the puddle wasnít really under the end of that tubing. I found fresh coolant on my hand after feeling below the center of the radiator but couldnít find where the fluid was coming from. I donít get it. The engine temp is always normal on the range. Could this be a hose clamp problem somewhere? If anyone has any ideas Iíd sure appreciate hearing them. Thank you.
    Vic
  2. #2
    Join Date
    Jul 2003
    Posts
    142
    Default Re: 3520 Radiator Issue
    I would suggest starting with the hose clamps. Try to tighten them a bit. If you find one that tightens easy, then you likely have found the problem. While tightening, also make sure the clamps aren't back too far from the end of the hose. There is a slight bump or bead near the end of the pipes that the hoses push onto. If a clamp is placed patially on that bead then it may not clamp correctly.
    Try this first, then let us know the results.
  3. #3
    Join Date
    Feb 2006
    Posts
    64
    Upstate NY
    JD 4044R
    Roger,
    Makes sense to me. I'll try it today. TGIF!
    Vic
  4. #4
    Silver Member NoMo's Avatar
    Join Date
    Sep 2004
    Posts
    238
    Talala, OK
    John Deere 3520
    Any luck fixing this leak yet?
  5. #5
    Join Date
    Feb 2006
    Posts
    64
    Upstate NY
    JD 4044R
    Sorry for the delay in replying but I wanted to get some experience before providing an update. I tightened the hose clamps a bit and I added enough Cool-Gard to bring the recovery tank up to the full cold line. I have not had any puddles on the floor since. It seems too easy, doesn't it? Thanks for the advice.
    Vic
  6. #6
    Join Date
    Sep 2004
    Posts
    238
    Talala, OK
    John Deere 3520
    That's great! Thanks for the update.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
