Neophyte
I have a 3320 with 300CX and 73" HD Bucket.
When I purchased my tractor, I decided not to load the tires. I did this because I was going to be using my RFM quite a bit and I wanted to be able to drop the extra weight. I ran this past my dealer and he did not seem to think it was going to be a problem as long as I used my ballast box when using the FEL.
I have the iMatch with JD ballast box (without extension) that is filled with crushed stone.
I was using the FEL on some wet loam today and I lifted the rear tires a couple of times. At one point, I mis-loaded the bucket with most of the load on the left side and the right rear tire came off the ground quite a bit. It was very unnerving. After using mostly skid steers and TLBs, I'm not used to this balancing act.
I was reading through the 300CX manual tonight and saw the following about the required minimum ballast.
Minimum Ballast = Fluid Filled Rear Tires & 1100 lb of 3-Point Hitch Ballast & 3 Wheel Weights per Wheel
Does anyone actually ballast their machine this much? How much does this add up to? How much weight do 3/4 filled tires add? How much does each rear wheel weight add?
According to the manual, a ballast box (without extension) should way between 608 lbs (sand) to 824 lbs (concrete). I'm using crushed stone, which should weigh at least as much as sand.
I'm wondering if I should have loaded my tires but I really don't want to be stuck with that weight when mowing.
I have seen some pictures out there of people adding weights to the sides or back of their ballast box. Besides the sand, how much weight can one add to the ballast box?
At a minimum, I'm thinking I may definitely want to get rear wheel weights. These can't be as easily removed as a ballast box but at least I can remove them when I start using my loader less. How much do these cost and are they easily installed/removed?
I also noticed that the larger R4 Marathoners (43x16-20) were not listed as approved rear tires for the 300CX loader. Is this because they are not actually approved or is this because they were a late addition and have not been added to the manual yet?
Do you think I should have loaded my rear tires? Any other suggestions?
