GaryBDavis
Gold Member
I’m using a WR Long brush grapple and Tree Terminator tree shear on my JD5420. I’ve got both attachments configured for my 542 FEL. For hydraulics, I’m using a Hyvair solenoid valve that is connected through my power beyond. I mounted the Hyvair near the FEL so the attachments hook up in the same area as the factory hydraulics for the FEL.
I had one fellow at a JD dealership tell me they make a grapple hydraulics kit for the 542 loader. He indicated it was a set of disconnects and a couple of steel lines that ran alongside the four lines that normally come on the 542 FEL. He said they converted to rubber hoses where FEL connects to the tractor. Up front, they have disconnects that mount on the front bar near the bucket. I’m thinking this is a kit made for the 5425 which has an optional three valve FEL port.
I’d like to shorten my grapple and tree shear hoses to simplify things when I switch between the two. However, my local JD dealership isn’t very knowledgeable and won’t bother to do some research. Can anyone here point me to a part number for this kit?
Thanks.
Thanks.
