Results 1 to 7 of 7
  1. #1
    New Member
    Join Date
    Jul 2006
    Posts
    3
    Default Function of work light kits on 2520
    Hi,
    Was considering getting the light kits to install on my fairly new tractor. After looking at the online configurator of the John Deere website, it implies that you canNOT have both the front and rear work light kits installed at the same time. The online parts diagram for the tractor does not give much help. I cannot tell if the wiring harness of the tractor will support both kits being installed. Does anyone with a 2520 have both kits in use?
    For that matter, what control is used to turn the work lights on/off?
    Regards,
    swregs
  2. #2
    Platinum Member Shawk's Avatar
    Join Date
    Nov 2005
    Posts
    572
    Iowa
    John Deere 3520
    Default Re: Function of work light kits on 2520
    Yep... My dealer said no sweat. Didn't upgrade my alternator either. Post your email addy & I'd be glad to drop you a couple pics...
    JD 3520 - eHydro, R4 tires, 165 FEL w/61" hd bucket, 48" Pallet Forks & bale spear (from Palletforks.com), Frontier 2060bb,72" rear blade, Farm Pride 3 pt snowblower 50", JD 655 tiller, Frontier 3pt Spreader, Ballast Box & i-Match
  3. #3
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,965
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    If it's like my 4110, witch it probably is...there is one wire uder the seat for a worklight that goes "hot" when the headlights are on.
    The factory switch and wire harness probably cannot support to much current draw.
    You can however add a relay and add all the lights you want within reason...
    Here is a thread that detailed my light install:
    http://www.tractorbynet.com/forums/c...t-install.html
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  4. #4
    Join Date
    Aug 2006
    Posts
    96
    Shady Grove, PA
    John Deere 4320
    Hello. I have just installed the forward aux lights and ROPS brush guards on my 4320. It was very easy. When i picked them up at my dealer, I got into an argument with the parts guy about whether or not the rear work light will work with the setup. He says no, that it's either the forward OR the rear light. Both won't work. However on the JD website it actually illustrates a 4000 series tractor with both front and rear light installed. However, when i was reading the instructions that came with the forward lights, it said that the switch can only handle 3 lights (ie 2 forward and 1 rear). The thing is, the wiring harness comes with connectors for rear work lights on BOTH sides. What the heck? Nobody from Deere seems to know. Anyone have advice? Will it melt the switch if i put 2 rear lights on in addition to the fronts? The alternator/battery should handle it... right?
  5. #5
    Gold Member Hard's Avatar
    Join Date
    Oct 2005
    Posts
    409
    Maryland
    JD 2320
    Picture of 2 worklights installed facing the rear on my 2320. They are mounted to the brushguards. The dealer did the install. All JD parts.
    Attached Images Attached Images
    JD 2320, 200cx FEL w/ 61" bucket, 62D OnRamp MMM
    Woods box scraper, Woods PHD25, Woods 5' rear blade, King Kutter Medium Duty Pro 6' rear blade, Woods 5' landscape rake, SpeeCo Quick Hitch
    JD 320 Lawn & Garden Tractor, 48" mower deck
    Formerly owned:
    2004 Cub Cadet (BY MTD) 5234D:
    2006 Cub Cadet (BY MTD) 5234D:
  6. #6
    Join Date
    Nov 2005
    Posts
    658
    Guildhall, VT
    JD 2305/JD 4720 cab
    It's not alternator capacity I think it simply has to do with the mounts and/or the factory wiring connectors. On each of my brush guards you can only mount a single light, forward facing or rearward facing.
    I have a 2305 and put on the front lights on the brush guards. I then welded a tab to the top of my tops on the rear and mounted a 55watt rear facing work light. Ran the wire through the rops (folding) and hooked it up to the work light harness. I actually like the high position much better as it lets me light 'down' on the work rather than just light up the implement I have hooked up.
    No problems at all with the 20 amp alternator.
    Also, the work lights hook up to the tail light harness so they are on all the time when the lights are on. If you hook up to the work light harness it will go off when the flashers are on. (I think so you don't blind folks behind you if you were on the road).
    "I'd rather be on my Tractor"
  7. #7
    Bronze Member PLUMBER's Avatar
    Join Date
    Jan 2006
    Posts
    61
    Fairfield county , CT.
    JD 2520
    I installed the JD lights on my ROPS and just turned one forward and one back gives you plenty of light , i tend to look to my left so i used the left light as a back up light seems to work real well and i dont get blinded when i look back
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
