The light blinks 1 time fast, followed by 3 times slow. QUOTE]
The code that you describe indicates that an HST solenoid coil either is shorted out or has an open circuit. Possible causes that I can think of include:
1. Solenoid burned out.
2. Wiring harness or connection is broken
3. Short in wiring harness
4. Controller partially burned out.
If you were working in tall weeds or brush, then I would first look for potential areas where the wiring harness could have been snagged. The wires to the solenoids come out a hole on the right side of the tractor, just under the front of the foot deck (I think). If you can find the wires, then you may be able to trace them. Does your tractor have a protective cover on the underside middle of the tractor? If that is missing, then the solenoids are rather exposed and one could have been damaged. If you remove that cover, then you can start tracing the harness back from the solenoids.
If you have a ohm meter, you can also check the solenoids by disconnecting the short leads from the harness and measuring the resistance across the two pins.
