Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    Gold Member
    Join Date
    Aug 2005
    Posts
    428
    West TN
    JD 3520 eHydro
    Default 3520 300CX hose routing
    The lines from the 300CX to the 3520 are chafing the side of my hood. Not the end of the world, but wonder if there is a way to prevent it. What do you all do to minimze this?
    2006 JD 3520
    300CX, Frontier BB2060
    1977 JD 214, 47 deck, 23" ags
  2. #2
    Join Date
    Sep 2005
    Posts
    159
    Central New Hampshire
    JD 3320
    Default Re: 3520 300CX hose routing
    Quote Originally Posted by jmt1271
    The lines on my 300cx are bundled inside a black mesh protective enclosure as they pass by the hood. This is the way that the 3320 was delivered. No sign on a problem.
    JD 3320 eHydro, 300cx FEL; HD '95 FXDS; '04 Ram 2500 plow truck, 2012 Toyota Tundra
  3. #3
    Gold Member
    Join Date
    Aug 2005
    Posts
    428
    West TN
    JD 3520 eHydro
    Mine are in the mesh as well. The problem is the mesh is against the side of my hood, right side, near the front wheel. As the tractor moves and/or I lift the loader arms, it rubs against the hood. It is scuffing the plastic.
    2006 JD 3520
  4. #4
    Join Date
    Jun 2006
    Posts
    1,436
    Wheeling, WV
    2006 JD 3520 w/cab & 300CX loader. 1995 JD 870 w/440 loader & 8b backhoe.JD 455 w/54" mower deck.
    Jason, I'll try and send some pics in the next couple of days of my 3520 w/ 300CX loader. The hoses are close,but not rubbing. Rubbing the hood would be unacceptable to me. Try and tweek the hoses by disconnecting them and putting a twist in them so they want to push away from your hood.
    "Good judgement comes from experience.Experience comes from bad judgement."
  5. #5
    Gold Member
    Join Date
    Aug 2005
    Posts
    428
    West TN
    JD 3520 eHydro
    Quote Originally Posted by dirtworksequip
    Lookimg forward to the pics.
    2006 JD 3520
  6. #6
    Elite Member
    Join Date
    Jul 2006
    Posts
    3,010
    midwest
    JD 4520, Toolcat 5610, Bobcat S300, Case-IH 125 Pro, Case-IH 245, IH 1086, IH 806
    I used a large zip tie and pulled them closer to the loader. Zip tie can be cut if needed. Easy fast fix. Got large zip ties from Menards. You could also connect zip ties end to end if have smaller zip ties to make a longer one.
  7. #7
    Join Date
    Nov 2005
    Posts
    237
    Barton, Or
    JD 3520 eHydro
    My 300CX has black plastic retainer clip gizmos that tie the bundle to the loader arms. The clips snap into small holes in the loader.
  8. #8
    Gold Member
    Join Date
    Aug 2005
    Posts
    428
    West TN
    JD 3520 eHydro
    Mine is clipped also. But it still gets against the cab. I was wondering if mine is routed improperly.
    2006 JD 3520
  9. #9
    Gold Member
    Join Date
    Aug 2005
    Posts
    428
    West TN
    JD 3520 eHydro
    I said cab, but meant it gets against the hood. I only wish I had a cab.
    2006 JD 3520
  10. #10
    Bronze Member hankus's Avatar
    Join Date
    Oct 2006
    Posts
    71
    Edgewood, WA
    JD 3120
    I hadn't noticed any problems on my 3120 w/300cx, but I just checked and where the mesh is held in place against the inside of the lifts' arm I can see where the plastic clip is just touching my hood. It may be this clip can be tighten up a bit to provide clearance, since it doesn't feel very tight.
    Hank
    JD 3120, 300cx FEL, 447 BH w/Rankin Thumb
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
