Page 1 of 2 12 LastLast
Results 1 to 10 of 19
  1. #1
    Member
    Join Date
    Aug 2005
    Posts
    33
    Topsfield, MA
    JD4300
    Default Help with power beyond and log splitter
    Folks,
    I'm looking for some guidance on hooking up a 3PH log splitter to my JD4300. The previous owner had a back hoe and I believe had the power beyond kit installed. I've attached a photo of the back end of the tractor.
    My log splitter mounts to the 3 point hitch and has two hydo lines, one supply, one return. Where should I hook the log splitter lines to? I've labeled the tractor hydraulics as A, B and C.
    Thanks.
    Mark
    Attached Images Attached Images
  2. #2
    Platinum Member B8FISH's Avatar
    Join Date
    Jan 2004
    Posts
    589
    West Bloomfield, NY
    JD 3320
    Default Re: Help with power beyond and log splitter
    Hi--I believe that you should connect to A & B as C is used when the BH is on (disables the 3PH). If you connect to A & B then you can use the 3PH to raise the splitter to a comfortable working height.
    3320 300CX w/teeth, 448BH, MX-5 ,5' BB, 6' rear blade, JD 757ZTR, MS261, MS211
  3. #3
    Member
    Join Date
    Mar 2007
    Posts
    44
    SHIRLEY, MA
    1996 JD 755 / 2000 JD 4700
    Quote Originally Posted by B8FISH
    Right On
    JD755 - 70 FEL - Land Pride Finisher - 47" SnowBlower
    JD4700 - 460 FEL - 48 Backhoe - 4th & 5th SCVs
    All this on 3/4 of an acre. I own more tractors than cars
  4. #4
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,960
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    B8FISH is absolutely correct, happy splitting
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  5. #5
    Bronze Member savageayape's Avatar
    Join Date
    Nov 2006
    Posts
    66
    Spencer Indiana
    JD3520
    They are correct, but you should make sure you connect the hoses correctly. In other words.. make sure the flow is going the correct direction from the tractor to the splitter and then back to the tractor. You will need to have hydraulic hoses made. You can get the correct ends for the hoses from your JD dealer and then have them attached to hoses from someone who makes hydraulic hoses... you also need to make sure you know what size the fittings are for attaching the other end of each hose to your splitter.
  6. #6
    Bronze Member hankus's Avatar
    Join Date
    Oct 2006
    Posts
    71
    Edgewood, WA
    JD 3120
    Having the same setup on my 3120, I'm curious about the direction of flow and how you detemine which direction other than trial and error. Would it be out A and in B, or are there markings at the fittings that I haven't seen?
    Hank
    JD 3120, 300cx FEL, 447 BH w/Rankin Thumb
  7. #7
    Member
    Join Date
    Aug 2005
    Posts
    33
    Topsfield, MA
    JD4300
    Hankus....I'd like to know that too. Anyway, thanks for the info, my splitter has 3/8" hydo lines installed, I just need the quick disconnect couplers, I'll be making a visit to a local shop to get those. Once I figure out which is supply and which is return, I'll be set to split. Its a good thing, this winter just doesnt want to give up here in New England. I'm down to my last weeks worth of wood, went through nearly 5 cord this winter!
  8. #8
    Join Date
    Jul 2003
    Posts
    12,960
    Westminster, MD
    Quote Originally Posted by hankus
    OK guys, this is simple...
    The fluid flows OUT of "B", the fixed hose. And can flow IN to either port "A" or "C". But as B8FISH already said, Plugging into the "C" port will disable the 3PH, while the "A" port will not.
    KennyD
    www.boltonhooks.com
  9. #9
    Join Date
    Jul 2003
    Posts
    12,960
    Westminster, MD
    Quote Originally Posted by mlip
    As for the 3/8 hose, you just want to make sure that the hose is at least the same size as the "loop" you are connecting to. You do not want to restrict the flow of oil through the splitter or overheating can occur.
    KennyD
    www.boltonhooks.com
  10. #10
    Member
    Join Date
    Aug 2005
    Posts
    33
    Topsfield, MA
    JD4300
    Kennyd....thanks, sounds easy enough. I will verify the hose diameters for possible restriction issues......BTW, I only got to use my plow set up once this winter. It worked great, but we didnt get much snow....at least when I was home......Mark
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
