Results 1 to 10 of 10
  1. #1
    Join Date
    Jul 2001
    Posts
    30
    Central New Jersey
    J.D. 4400
    Default 430 loader
    I purchased a 430 loader for my 4400. The first time i used it was today, and as soon as you lift any weight with it the back posts of the loader come right off the two square mounting tubes. Is it possible the dealer has the two side mounts reversed or are they the same? The loader goes on fine it just won't stay on once you lift any weight. Didn't get in touch with the dealer yet but he is about 90 miles away, so i would like to avoid bringing it in for service and repair it myself if possible. Also would anyone know the wrench size of the 4 bolts that hold the loader mounts on?
  2. #2
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    JD 4300, JD X485 JD 4x2 Gator, JD 425, JD455
    Default Re: 430 loader
    For sure something is not right. I will find out what the wrench size is in the morning, but I think 24mm is the one. Might need a socket to reach them. I will post a picture if all goes well so you can see if your side mounts are on the right side, and in the right position. Does the front bracket (with the locking latch) hook correctly onto the front weight bar? Do you have the 430 manual?
  3. #3
    MJB
    MJB is offline
    Gold Member
    Join Date
    Jun 2000
    Posts
    499
    Syracuse, New York
    1952 Case DC-4, 2001 JD4300 MFWD, HST
    There is definately a left and a right to the brackets. Here is a picture of the mount on my 4300. There is a lug on the back side of the square tube which centers the loader post side to side. This lug should be located between the forked ends of the loader post when the loader is mounted properly. Something must be incorrectly installed or way out of adjustment for the loader to come off like that. Hope this helps.
    Attached Images Attached Images
  4. #4
    Join Date
    Feb 2001
    Posts
    73
    Kansas
    John Deere 4300
    The loader should not be comong off it's support posts.I think the problem lies in the adjustment of the front locking assembly.I clearly tells how to adjust in the 430 loader manual.Do you have the release handle pulled all the way back and in the retention slot?Th loader is obviously coming off the front mount or is not latched into place. since I dont have a scanner I can't put the manual pages on online.Maybe the scanmaster John Miller III could put pages 11 and 12 of the loader manual in a post so the whole tractor world can see it..Are you up to the task, John?
  5. #5
    Join Date
    Apr 2000
    Posts
    236
    NC
    JD 4100 HST
    I agree with all, there is something wrong with the installation. If the arms are not centered properly when the front is locked down or if the front is not locked down properly the rear arms will come off. I hate to say it but this appears to be operator error. The dealer should have provided a manual with the loader, re-read it carefully until you are comfortable with the operation. You DO NOT want the loader to jump off the brackets with a load on it.......
  6. #6
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    More information from you would be helpful. If the dealer installed the loader, then for sure contact him.
    I said I would post a pic, and am doing so. The two pics will compliment the one already posted.
    One is of the frame post that stays with the tractor, and the other is of the latch that has to be in the hole in the slot, locking the front plate to the weight bar. If any of this is confusing to you, and you have the loader manual, by all means get help from the dealer who may or may not know (depending on his experience and knowledge, or that of the person assigned to do the setup) how to help you.
    Set up correctly, there is NO WAY the loader can come loose from the frame posts.
    Your turn to provide some more information.
  7. #7
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    Second pic of the latch that has to be in the hole in the slot, locking the front plate to the weight bar.
    Please let us know if any of this is helpful.
  8. #8
    Join Date
    Jul 2001
    Posts
    1,807
    Sharpsburg, Md
    John Deere 4100 HST
    I have a 410 loader on my 4100.
    I had the left post come off of the mounting bracket one time. Scared the heck out of me. I disconnected the FEL, remounted it and have never had a problem since then. So I think I caused the problem when attaching the FEL prior to the problem. What the problem actually was I do not know!!! [img]/w3tcompact/icons/shocked.gif[/img][img]/w3tcompact/icons/blush.gif[/img]
    Couple of questions. Have you pulled the locking mechanism to lock the FEL to the weight bracket? Have you locked down the FEL with the latch on the weight bar? These two items are integral and ensure that the FEL is attached properly.
    I'm assuming that the FEL was still attached to your 4400 after installation. Or did you remove it and reattach it?
    Terry
  9. #9
    Join Date
    Jul 2001
    Posts
    30
    Central New Jersey
    J.D. 4400
    beenthere,
    the picture you sent was very helpful. the posts that stay on the tractor are reversed on mine, the tab that sticks out is angled down not up like yours. i reversed the two sides and everything is fine. the dealer installed them wrong. thank you & everyone else for the help polaris
  10. #10
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    Thanks for the feedback, as it makes it all worthwhile.
    Now I noticed that I need to get some paint on those stubs as they don't look so good.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
