mfreund
Check to see if the rockshaft rate of drop knob is screwed all the way in. That will stop it from raising
I am 99.9% sure there is no switch's on the 4x00 series machines...
Diagram below of the rockshaft linkages:
I have never seen that switch on mine.
Kennyd,
Do you know anything about that "oil suction screen"
It says in the manual, that if it gets clogged the 3-point hitch won't work.
The 4x00 series machines used the model 47 and 48 hoes? With the early rockshaft attachment system? 3pt disabled with hoe - what type mechanism?
Ok, so the x10 series and the x20 series came out with the sensor switch... learn something new all the time.
Thanks.
AKfish
