Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Jan 2012
    Posts
    13
    John Deere 3010 Gas
    Default Taking Air Cleaner Stack Off Hood
    I got the hood off my gas 3010, but had to take the air cleaner stack off with it. How does the top portion of the stack separate from the rest of the air cleaner ( or is mine just stuck by age). See attached photo.
    Attached Thumbnails Attached Thumbnails Taking Air Cleaner Stack Off Hood-air-cleaner.jpg
  2. #2
    Join Date
    Jan 2007
    Posts
    1,923
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Default Re: Taking Air Cleaner Stack Off Hood
    One just takes a dead-blow mallet or hammer and tap parts key #10 off of parts key #2
    Attached Thumbnails Attached Thumbnails Taking Air Cleaner Stack Off Hood-r997___________un01jan94.gif
  3. #3
    New Member
    Join Date
    Jan 2012
    Posts
    13
    John Deere 3010 Gas
    Tx Jim, thanks for the help. The hood is off and ready for sandblasting, and also can now get to the selective control unit.
    In another post I talked about the hydraulics problem I'm having. The 3-point either won't work, works slowly, or when it does and I try to raise it, the front loader raises also. Separately, the engine will also load up and quit, and at the same time the power steering goes out.
    Do the power steering, the 3-point hydraulics, and the remote cylinder for the front loader all have the selective control valve as the common point? If the valve is bad or out of adjustment, will it cause the problems the tractor is having?
    Should I try adjusting the selective control valve before installing a repair kit (AR 34295)? Not sure what to do. Also, the service manual doesn't really tell how to adjust the selective control valve.
    thanks, Bob
Similar Threads
  1. Terra-Dome Earth Shelter Build
    By SamWalton in forum Projects
    Last Post: Today, 02:09 AM
  2. air cleaner filter for 2015
    By crackercap in forum Mahindra Owning/Operating
    Last Post: 10-20-2009, 11:40 PM
  3. homemade air compressor
    By Dan69GTX in forum Build-It Yourself
    Last Post: 10-04-2007, 09:00 AM
  4. Kubota air cleaner light?
    By daveinnh in forum Kubota Owning/Operating
    Last Post: 08-02-2007, 09:22 PM
  5. Air Cleaner Upgrade?
    By Iplayfarmer in forum Customization
    Last Post: 04-19-2007, 02:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
