Results 1 to 5 of 5
  1. #1
    Join Date
    Aug 2008
    Posts
    62
    Purcell, Oklahoma the middle of no where
    Yanmar 2210, and 2, 425 John deere lawn tractors
    Default 1964 John Deere 1010 Barn find.
    I found this John Deere 1010 with a wide front end. I have not set my own two eyes on it yet, have only seen pictures of it. Man wants 1000 dollars for it as it sets. He says it was/is and will be once again a great running tractor. He removed the head to have it worked over. Needed some new valves and springs. He stated that it has been magnafluxed and there where no cracks.
    My question: Is this the old engine that has the plate and sleeves all attached together. I've heard about them but have never seen one. If so does it take any specialty tools to remove or can your average joe do it. Are parts still available? Overall is this a decent little tractor for a small acerage. Is a thousand dollars a good deal?
    Here are the pics that I have seen.
    Attached Thumbnails Attached Thumbnails 1964 John Deere 1010 Barn find.-1010-01-jpg   1964 John Deere 1010 Barn find.-1010-02-jpg   1964 John Deere 1010 Barn find.-1010-03-jpg
  2. #2
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,232
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Default Re: 1964 John Deere 1010 Barn find.
    Yes it has a sleeve plate. Is it gasoline or diesel? Diesel weren't as dependable. Value of tractor is determined by location and what's wrong with it. $1000 not too bad if you can get it to start.
  3. #3
    Join Date
    Aug 2008
    Posts
    62
    It's gasoline. He has the head pulled off of it right now. Says he moved or found a new job 200 miles away and doesn't have the time to deal with it. I'm going to look at it this weekend if he makes it up this way. Atleast having the head off will allow me to look at it better, Right? Location wise, it's only 10 miles down the road from me. Heck I could pull it home lol.
    Thanks for the info!
  4. #4
    Join Date
    Jan 2007
    Posts
    7,232
    Coyote Flats,Tx
    By location I meant Ok or CA or Ia or NY or Fl not minimum miles. IMHO gasoline engine is much better on 1010 than diesel. Diesel had a tendency to be hard starters,smoked excessively on start up and prone to cranking cyl heads.
  5. #5
    Join Date
    May 2010
    Posts
    137
    Brighton, Tn.
    Mahindra 4110 FEL, New Holland TC40 FEL and Backhoe, New Holland TC29, IH Farmall 806 LP with FEL, Exmark Zero Turn
    I had a 1010 about a year ago. Gas, ran good, needed brakes. I got 1000 for it. I will send you email or PM about it.
    Bill
    Bill Beyer
    Brighton Tn.
Similar Threads
  1. John Deere 1010 won't stay running
    By NewtoBolens37 in forum Parts/Repairs
    Last Post: 04-04-2012, 05:44 AM
  2. Snowblower John Deere 47" Snowblower PTO shaft vibration
    By xmineman in forum Attachments
    Last Post: 01-28-2012, 09:38 PM
  3. Dealer Another Deere dealership pulled
    By dgl24087 in forum John Deere Buying/Pricing
    Last Post: 01-29-2010, 07:36 AM
  4. Replies: 3
    Last Post: 02-09-2009, 07:19 PM
  5. John Deere 2010 Bulldozer/Crawler
    By mitchdb in forum John Deere Owning/Operating
    Last Post: 02-17-2004, 01:02 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
