Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Super Member flusher's Avatar
    Join Date
    Jun 2005
    Posts
    5,689
    Northern California-Tehama Co.
    2008 Mahindra 5525, 1964 MF-135 diesel, 1951 Farmall Super A, 1951 Minneapolis Moline BF, 1945 Oliver 60 Row Crop, 1949 JD B widefront
    Default Re: John Deere B (1949, wide front)
    Thanks. Always interested in good stuff that TBNers have come up with. Looking forward to the pics and data.
  2. #12
    Silver Member birddog0304's Avatar
    Join Date
    Apr 2012
    Posts
    126
    Northeast TN
    John Deere/Massey Ferguson/Bobcat
    Default
    10 inches top horizontal
    24 inch vertical lift arms
    28 inch horizontal draft arms
    All are 2 1/2 x 1/2 inch metal.
    Very basic info, but if your interested I can get more detailed as well as
    measure the top link mount
    Attached Thumbnails Attached Thumbnails John Deere B (1949, wide front)-image-2274208551.jpg
  3. #13
    Join Date
    Jun 2005
    Posts
    5,689
    Thanks for the info and the photo.
    I've seen this design before and have doubts about the strength of that frame that supports the two lower lift arms--it looks like it's made of relatively small size steel angle which seems to me to be a weak point in the design.
    I like this design shown below. The lower arms are attached to the four studs on the axle via those two large angle assemblies.
    John Deere B (1949, wide front)-jd-b-3pt-better-design
  4. #14
    Join Date
    Apr 2012
    Posts
    126
    Northeast TN
    Default
    That's 2 1/2 inch angle bolted to the drawbar frame. As far as strength, I tested it one day with a 7 ft finish mower. Yes I know that's a hp mismatch, but I started it slow and ran it slow, plus I was looking for a reason to to drive the 50. Back to the point, it lifted the front off the ground before I added weight, then lifted the mower. Wow if I had the choice though, I like the looks of yours better. Do you have hydraulic outlets on the back?
  5. #15
    Join Date
    Jun 2005
    Posts
    5,689
    Quote Originally Posted by birddog0304 View Post
    Yes, the PowerTrol hydraulics unit bolted onto the rear of the axle housing has a pair of outlets for connecting a hydraulic cylinder. IIRC PowerTrol was standard on the late model Bs (mine is a 1949).
    My problem is that there are only 3 good studs on the axle now for attaching those two yellow support plates shown in the previous photo. The hole for the 4th stud has rusted threads. I'll have to ream out that hole and tap it for a Keensert or something like that so I can thread in that 4th stud. Old tractors can be a PITA at times
  6. #16
    Join Date
    Apr 2012
    Posts
    126
    Northeast TN
    Default
    Looking at a schematic from parts catalog I found the draft links pivot from a bracket mounted to to the drawbar frame( similar to mine). That being said I'm would think that would be plenty strong. What were you planning on lifting? Didnt know powertrol was standard on a 49 B. Do you have dummy plugs for your powertrol?
    Attached Thumbnails Attached Thumbnails John Deere B (1949, wide front)-image-3567075411.jpg
  7. #17
    Join Date
    Feb 2012
    Posts
    594
    Staunton, VA
    John Deere 3038E
    Saw a 49 B tricycle with custom trailer go at auction in Stuarts Draft, VA Saturday for $4,000. It seemed to run good, but was obviously restored and used in some shows. I don't know if that was a good price and didn't have time to check, so I passed. But I was tempted.
  8. #18
    Join Date
    Jun 2005
    Posts
    5,689
    Here's a look at the rear of my JD B
    That bracket just supports the rear end of the drawbar. It may support a few hundred pounds of tongue load like you'd have with a small square baler like my MF124. But I'd like something more substantial for a 5-6 foot brush hog.
    PowerTrol--just a guess that it was standard in 1949. Maybe it was PowerLift.
  9. #19
    Join Date
    Apr 2012
    Posts
    126
    Northeast TN
    Default
    Like I said mine will lift a 7 ft bushhog brand finish mower. I see you have the dummy plugs in. Before you ream that forth hole out, have you tried some PB blaster and an appropriate sized tap. Might be enough to clean the threads up.
  10. #20
    Join Date
    Jun 2005
    Posts
    5,689
    All there was in that hole was rust flakes. No threads left in the casting.
Similar Threads
  1. John Deere 1600 wide area mower help!
    By subergoo in forum Parts/Repairs
    Last Post: 05-05-2013, 06:57 PM
  2. John Deere 4010 Wide Front question
    By stano4010 in forum John Deere Buying/Pricing
    Last Post: 11-07-2011, 11:16 AM
  3. 1949 John Deere MC fan bearing lubrication
    By jd49 in forum Customization
    Last Post: 05-02-2011, 10:43 PM
  4. 1949 John Deere MT
    By Deere40Fan in forum John Deere Vintage Tractors
    Last Post: 03-12-2011, 08:33 PM
  5. john deere 1949 B value
    By Mark_in_IN in forum John Deere Buying/Pricing
    Last Post: 10-09-2009, 03:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
