Results 1 to 6 of 6
  1. #1
    Gold Member BlackRaptor's Avatar
    Join Date
    May 2008
    Posts
    382
    SEMN
    John Deere 3320
    Default john Deere 70
    Okay I feel very stupid about this.
    Where is the oil dip stick on the 70? Before winter I want to change all fluids but having trouble finding it. Or is it one of those fill holes you fill till it runs out ? Last what weight oil ? It's a 1954. Thanks
    Chad.
    2012 John Deere 3320 Cab 300CX FEL
    2010 John Deere Z910a
    1962 JI Case 830 wide Front
    1960 Farmall 460 Narrow Front
    1954 John Deere 70 Wide Front FEL
    1947 Farmall M Narrow
    1945 Farmall H Narrow
  2. #2
    Veteran Member grnspot110's Avatar
    Join Date
    May 2007
    Posts
    2,262
    MO
    John Deere 1953-40S, 790, 755, 314, 70 I & Power King 2418
    Default Re: john Deere 70
    No "dip stick"! Look under the belt pulley & slightly forward, you will find a long hex nut with another nut in it's outside, unscrew the outer nut a couple of turns to check the oil level. There is a hole in the bottom of the long nut, when oil drips from the hole (with the outer nut loosened) it's full. Just make sure the hole isn't plugged (which it usually isn't). ~~ grnspot
  3. #3
    Super Member
    Join Date
    Apr 2004
    Posts
    6,503
    East Coast of Lake Huron
    Deere, several
    1-800-522-744& because there are dozens more hidden surprises waiting to be checked. Also get a torque wrench and check the flywheel bolts. Who knows what pending disaster a previous tinkerer has left for you.
  4. #4
    Elite Member
    Join Date
    Sep 2010
    Posts
    4,100
    CANADA
    Many
    The oil for it would most likely be a 30 weight for summer, 20 weight for fall and spring and 10 weight in the winter. What variant to the model 70 is yours. 70, 70D, 70S or 70 high-crop?
  5. #5
    Join Date
    May 2008
    Posts
    382
    SEMN
    John Deere 3320
    Thanks for getting back to me.
    It's a 70 wide front gas.
    I attached a couple pictures they are not very good though the 3320 is blocking it.
    I need to go through all nuts and bolts and tighten everything. soon as i finish my shop in the shed the whole tractor is getting broke down for a complete restore/rebuild.
    This was my grandpa's tractor i have so many memories of riding on this tractor when i was as young as 3. spent many hours growing up riding with him on it. so i want to restore it back to perfect.
    john Deere 70-imag0005-jpgjohn Deere 70-imag0007-jpgjohn Deere 70-imag0008-jpg
    Chad.
  6. #6
    Join Date
    Oct 2012
    Posts
    131
    Windham
    John Deere 70
    Nice Black raptor especially with that heritage.Also restoring a 70 gas, just getting geared up to pull the cylinder case and the crankshaft.I grew up around John Deere two cylinders and always loved them.So far have restored a 50 and a 60,and loved every minute of it.
    Mike Ross
Similar Threads
  1. Replies: 10
    Last Post: 07-03-2012, 05:33 PM
  2. John Deere 50
    By suntreemcanic in forum John Deere Vintage Tractors
    Last Post: 02-29-2012, 01:55 AM
  3. John deere 325 vs. John Deere GT 235
    By jltrent in forum John Deere Lawn & Garden
    Last Post: 02-02-2011, 09:04 AM
  4. JOHN DEERE 650 DIESEL TRACTOR W/JOHN DEERE 272 GROOMING DECK*RUNS GOOD
    By mr.haney in forum Private Party Ads Archive
    Last Post: 10-25-2010, 02:15 PM
  5. John Deere 790 and John Deere MX5 Will it Work?
    By TerryWorkman in forum John Deere Owning/Operating
    Last Post: 02-13-2005, 04:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
