Results 1 to 2 of 2
01-24-2013, 01:17 PM #1New Member
- Join Date
- Jan 2013
- Posts
- 3
- Location
- hays, ks
- Tractor
- john deere
2510 and 3010 no 3rd gear
I have a 2510 and a 3010 with the same problem. Neither will move in 3rd gear. It seems they try to engage but then nothing. All other gears on both tractors work fine both forward and reverse. No issues. 3rd gear has probably had the most use of all gears on both tractors if that helps.
Thank you
01-25-2013, 07:32 AM #2Veteran Member
- Join Date
- Jan 2007
- Posts
- 1,905
- Location
- Coyote Flats,Tx
- Tractor
- JD 4255/Kubota M7040 HDC
Re: 2510 and 3010 no 3rd gear
First thing to do is check for looseness & adjustment in shift rods and shift quadrant.
Similar Threads
1405 cub cadet transaxle slipping in 2nd and 3rd gear
By hleach in forum Parts/RepairsReplies: 4Last Post: 12-05-2012, 04:34 PM -
Gear shift stuck in 3rd
By Tlr2 in forum Mahindra Owning/OperatingReplies: 7Last Post: 11-14-2012, 11:20 AM -
TN65 NO 3rd or 4th gear
By adamh502 in forum New Holland Owning/OperatingReplies: 4Last Post: 11-06-2011, 09:37 AM -
cant find 1st and 3rd gear
By COASTBUSTER in forum Parts/RepairsReplies: 2Last Post: 08-18-2011, 08:51 PM -
Stuck in 3rd gear
By jeffery in forum Kubota Owning/OperatingReplies: 0Last Post: 09-04-2000, 05:37 PM
