Results 1 to 9 of 9
  1. #1
    New Member
    Join Date
    Jan 2013
    Posts
    4
    syracuse, nebraska
    john deere 50
    Default john deere transmission noise
    I have a 1953 john deere 50, it has a noise in 3rd gear, when I have my sickle mower hooked to it seems to pull the engine down almost to the point where it kills the engine. Do I have a bearing going out or something else?
  2. #2
    Join Date
    Jan 2007
    Posts
    1,892
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Default Re: john deere transmission noise
    It sounds as if there's a bad bearing in trans.
  3. #3
    Elite Member MIKE R's Avatar
    Join Date
    Sep 2010
    Posts
    3,468
    PRINCE TOWNSHIP, ONTARIO
    MASSEY 1020 and 1945 CASE SC, 1914 1 1/2 hp EMPIRE HIT AND MISS ENGINE
    Default
    Quote Originally Posted by Tx Jim
    I agree. Or the gear is missing teath.
    Any more info on the noises and such that its making.
    "If the women don't find you handsome, they should at least find you handy" - Red Green
    PRINCE TOWNSHIP TRACTOR CRUISE WEBSITE
    https://sites.google.com/site/prince...torcruise/home
  4. #4
    New Member
    Join Date
    Jan 2013
    Posts
    4
    syracuse, nebraska
    john deere 50
    It is a knocking or chattering noise and it is also faintly heard in first gear also. The sound is coming from the right side of the operators platform.
  5. #5
    Join Date
    Sep 2010
    Posts
    3,468
    Does it do it in reverse?
    1st, 3rd and reverse all are the same gear. Most likely a bad bearing on the top shaft. If you let it get worse you could end up with enough play that will allow it to jump out of gear. You should be able to hear and solve which is the bad bearing by putting a screwdriver on the casting near the bearing and putting your ear to the end of the screw driver. It acts like the thing doctors use to check your heart.
    If you remove the top cover you will be able to feel the shafts and see which ones loose.
  6. #6
    New Member
    Join Date
    Jan 2013
    Posts
    4
    syracuse, nebraska
    john deere 50
    I have not noticed it making noise in reverse. Thanks for the info. I hope to start restoring it this winter.
  7. #7
    Join Date
    Sep 2010
    Posts
    3,468
    Default
    We will need pictures.
  8. #8
    New Member
    Join Date
    Jan 2013
    Posts
    4
    syracuse, nebraska
    john deere 50
    My dad's 1955 john deere 50 that I restored 10 years ago and 44 plow I restored last summer in 2012 otoe county fair parade.
    behliros
  9. #9
    Elite Member
    Join Date
    Dec 2007
    Posts
    3,522
    Ohio
    JD 5520, 790 TLB-- Kub L4300, B7800, MX5100
    Bearing is my first guess as well and that's probably the only option. Photos of your restoration would be very appreciated.
    I had a #44 plow years ago and it did a beautiful job and pulled easy. Might still have the owner's manual for it. No wonder John deere went to the head of the class with such a quality plow..
    Don't sweat the small stuff...
Similar Threads
  1. John Deere LX178 Noise?
    By dreamen in forum John Deere Lawn & Garden
    Last Post: 03-17-2012, 05:06 PM
  2. John Deere Noise Canceling Headphones
    By Fug1000 in forum Kubota Owning/Operating
    Last Post: 11-08-2010, 09:57 PM
  3. John Deere 345 pto clutch noise.
    By mooseman214 in forum John Deere Lawn & Garden
    Last Post: 08-14-2010, 04:29 PM
  4. 4520 john deere power steering noise
    By xrjohndeere in forum John Deere Owning/Operating
    Last Post: 11-20-2009, 07:26 PM
  5. John Deere 850 rear end noise
    By JB4310 in forum John Deere Owning/Operating
    Last Post: 11-06-2009, 10:03 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
