Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    New Member
    Join Date
    Feb 2013
    Posts
    6
    Mulberry Grove Ill
    John Deere 110 tlb, + 5 others
    Default Re: 3020 jd diesel in oil
    If this is a old 3020 diesel you have a fuel pump on the right side, front of engine it has a weep hole in it you shood see some dirty oil by the pump. sometimes the weep hole gets plugged with dirt and if the pump goes bad it will put fuel in crankcase.
    The fix is a new fuel pump.
    Could be fuel injection pump, But I would replace the fuel pump first.
    Always check oil before start up
    Good luck treetrimmer01
  2. #12
    Join Date
    Jan 2007
    Posts
    1,944
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    I sure wish JD engineers hadn't numbered some of the CUT's using the same numbers as older JD tractors. It makes it very confusing.
  3. #13
    Silver Member duke7595's Avatar
    Join Date
    Jan 2012
    Posts
    196
    S/W MO.
    820 ,1520,1020 (D) 1020 (G) 1050,4020
    Quote Originally Posted by Tx Jim View Post
    Turn pump upside down and after replacing u-cup seals(parts key #18) on drive shaft,lubricate the seals then carefully slide the shaft into pump(being careful to line up dots) so as to not wrinkle the first cup back. The JD tractors that are very difficult to install inj pump without a tool are the models that the shaft stays in the engine
    Thank you for this information, I'm sure many of the members will appreciate it.
Similar Threads
  1. Oil & Fuel John Deere 3020 oil leak
    By rusty022 in forum John Deere Owning/Operating
    Last Post: 11-18-2009, 10:50 PM
  2. Oil & Fuel What type of oil should be used in a 3020
    Last Post: 11-18-2009, 05:49 PM
  3. Oil & Fuel Lift Capacity of 42A loader on JD 3020 Diesel
    By SpringHollow in forum John Deere Owning/Operating
    Last Post: 08-20-2007, 10:07 AM
  4. 3020 diesel $$$$$
    By Anonymous Poster in forum John Deere Buying/Pricing
    Last Post: 05-21-2001, 10:34 PM
  5. 3020 Deere Diesel $$
    Last Post: 05-20-2001, 10:22 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
