Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
  1. #11
    New Member cowboyup1717's Avatar
    Join Date
    Feb 2013
    Posts
    15
    Default
    It was in load L position
  2. #12
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,081
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Default Re: JD 2120 3 pt won't lower
    Did you move the lever to "D" and if so did that change anything?
  3. #13
    Join Date
    Feb 2013
    Posts
    15
    Default
    Trying now
  4. #14
    Join Date
    Feb 2013
    Posts
    15
    Default
    No change almost like the lever is not connected to anything inside.
  5. #15
    Join Date
    Jan 2007
    Posts
    7,081
    Coyote Flats,Tx
    I'll bet the spring(parts key #4) or the follower(parts Key#3) broke
    Attached Thumbnails Attached Thumbnails JD 2120 3 pt won't lower-l122863________un26oct95-gif
  6. #16
    Join Date
    Feb 2013
    Posts
    15
    Default
    I bet your right. I'll look where I drove yesterday. Not too far luckily
  7. #17
    Join Date
    Jan 2007
    Posts
    7,081
    Coyote Flats,Tx
    Both items I mentioned although on rare occasions have had a history of breaking. Bad side is one needs to R&R RS housing to see. Is you tractor open station or cab model?
  8. #18
    Join Date
    Feb 2013
    Posts
    15
    Default
    Open station
  9. #19
    Join Date
    Jan 2007
    Posts
    7,081
    Coyote Flats,Tx
    R&R of RS housing is fairly easy on an open station. If you decide to R&R RS housing I would advise to R&R 3 pt control valve o-rings while housing is off as the o-rings have a long history of leaking.
  10. #20
    Join Date
    Feb 2013
    Posts
    15
    Default
    Is the spring on the outside hooked to level and the draft selector
Similar Threads
  1. Does lower fuel mean lower rates
    By deere755 in forum Attachments
    Last Post: 04-06-2009, 09:46 AM
  2. Finishmowers-Lower & Lower prices!
    By HayDR in forum Attachments
    Last Post: 08-01-2005, 02:46 PM
  3. The 2120
    By grainger12002 in forum New Holland Buying/Pricing
    Last Post: 01-28-2003, 04:14 PM
  4. 2120 - Still Available?
    By timb in forum New Holland Buying/Pricing
    Last Post: 12-08-2002, 08:48 AM
  5. 2120
    By Anonymous Poster in forum New Holland Owning/Operating
    Last Post: 10-31-2001, 11:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
