2020 john deere engine
   / 2020 john deere engine #1
hernando
tennessee
dk 4510 kioti and a 450 case track loader
i am doing a in frame overhaul on a 2020 jd gas .,,, on the oil pump there is a oil line that goes to a small square block...i cant get to the bolts on one of the main journals without removing this..on the jd parts page it shows it attactched with a dowl,,but i cant figure out how this comes off,,,can anyone help ??? thanks for your time....bruce
   / 2020 john deere engine #2
If your tractors engine SN is < - 058459 then parts key #5 is a dowel so I guess you'll have to pry the block loose. You might be wise to invest in a JD service manual.
thanks for the reply ,,,,i am going to get tough and see what happens,,,thanks bruce
anyone else have any ideas...
   / 2020 john deere engine #5
On jims parts pic it just looks like it shoud pry off of the dowel after you take the bolt out of part #6.
