Results 1 to 8 of 8
  1. #1
    New Member
    Join Date
    Apr 2013
    Posts
    5
    Trenton, Fl
    JD 820
    Default JD 820 fuel transfer pump
    I have a JD 820 3 cylinder diesel that is leaking fuel into the crankcase. Suspecting the fuel transfer pump, I went to replace it. The local GreenSouth store and the JD online parts site both show two pumps, neither of which match the pump on my tractor or the gasket to the crankcase. (The hole in my tractor crankcase is larger than the new pump's gasket area.)
    I either need a source for the right pump, or a rebuild kit for the one I have. This is the German built 820 version.
    I can post pictures of the one I have if it will help.
    Thanks,
  2. #2
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,181
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Default Re: JD 820 fuel transfer pump
    This kit should work if your pump has the bowl on it. I don't understand how they could have sold you the wrong gasket as the same gasket(R27285 subs to R520618) fits many models including the famous "4020"
    Part Number: RE526203
    Replaces Part: AR60559
    Part Price: 39.28 USD
    Description: KIT,FUEL TRANSFER PUMP OVERHAUL
    Attached Thumbnails Attached Thumbnails JD 820 fuel transfer pump-l57229_________un01jan94-gif
  3. #3
    New Member
    Join Date
    Apr 2013
    Posts
    5
    Trenton, Fl
    JD 820
    Quote Originally Posted by Tx Jim View Post
    Mine doesn't have the bowl. The gasket area on the ones they have is smaller than the hole in the block on the tractor.
  4. #4
    New Member
    Join Date
    Apr 2013
    Posts
    5
    Trenton, Fl
    JD 820
    I finally got it figured out and got the right one.
    Thanks for the help.
  5. #5
    Gold Member duke7595's Avatar
    Join Date
    Jan 2012
    Posts
    324
    S/W MO.
    820 ,1520,1020 (D) 1020 (G) 1050,4020 2240
    Quote Originally Posted by Leslie Sapp View Post
    Thanks,
    I had the same problem with my 820, In my case it was the injection pump seals, it has 2 cup shaped seals once they go bad it allows diesel fuel to bypass into
    your crankcase.
    To replace them it requires a special tool for proper installation , hope this helps.
  6. #6
    New Member
    Join Date
    Apr 2013
    Posts
    5
    Trenton, Fl
    JD 820
    I got the new fuel transfer pump installed - I'm going to run it a while and keep an eye on the oil. If it's still getting fuel in the oil, the injection pump is the next suspect. She's purring like a kitten right now.
  7. #7
    Join Date
    Jan 2012
    Posts
    324
    S/W MO.
    YES SIR, they are a fine little tractor, if you have to change the seals in the injection pump you will need the proper tool , or in my case I let a mechanic friend do the job it saved me a lot of money.
    I can't remember the tool he used it was along time back, but the tool keeps the seals aligned . Good luck let me know how you make out.
    Duke.
  8. #8
    Silver Member Varmint1's Avatar
    Join Date
    Jun 2012
    Posts
    175
    Deville,La
    JD 1010, JD 970, Farmall Super A,Komatsu D20A-5,Ford 4500,Ford 4000 forklift,Ford 640 w/703 loader
    Default
    You can get one of the tools from a diesel pump shop, that's where I got mine years ago
Similar Threads
  1. Fuel Transfer Pump
    By DT86 in forum Oil, Fuel & Lubricants
    Last Post: 11-29-2012, 09:07 PM
  2. Transfer Fuel Pump Question
    By NCMau in forum Oil, Fuel & Lubricants
    Last Post: 01-15-2012, 10:56 AM
  3. Need Fuel Transfer Pump For 430 Lawn Tractor
    By JDinMaryland in forum John Deere Owning/Operating
    Last Post: 06-03-2011, 02:59 PM
  4. Oil & Fuel Fuel Transfer Pump
    By TonyC in forum Owning/Operating
    Last Post: 08-04-2003, 08:38 PM
  5. New "transfer pump" (fuel pump)
    By Richard in forum Parts/Repairs
    Last Post: 03-29-2003, 11:21 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
