Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    May 2013
    Posts
    1
    Independence, OR
    John Deere 820
    Default John Deere 820 3 pt. won't raise
    I have a 1969 JD 3 cylinder diesel, built in Germany. I have rebuilt the 3 pt. hydraulics and rockshaft. I didn't change any of the settings when I did the rebuild. I can't get the arms to fully raise up. They lift about 1/3rd of the way up and stop. I have connected a gauge to the port ahead of the pilot tube and only get a brief shot of pressure up to about 500 psi and then it drops back to zero. Any help would be appreciated.
    Thanks,
    Charles
  2. #2
    Join Date
    Oct 2012
    Posts
    131
    Windham
    John Deere 70
    Default Re: John Deere 820 3 pt. won't raise
    First thought would be fluid level,on the 2 cylinder tractors the two adjustments control raise and lower speed.Of course there is a bypass the hydraulics has to be deadheaded to get that reading.
  3. #3
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,165
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Where/what is the object you are calling a pilot tube? Where is L/D lever under seat setting(L-LD-D)? Lever should be setting in "D". Did you get the cam(parts key #9) back in correct place in RS valve control linkage? Also is spring(parts key #10) intact and attached correctly? It's possible that the L/D control mechanism needs to be adjusted following adjustments outlined in JD tech manual.
    Attached Thumbnails Attached Thumbnails John Deere 820 3 pt.  won't raise-l50399_________un01jan94-gif
Similar Threads
  1. John deere 820
    By Agoldman in forum John Deere Vintage Tractors
    Last Post: 07-20-2013, 03:21 PM
  2. John Deere 955 rear lift arms will not raise
    By wbaz in forum John Deere Ag Tractors
    Last Post: 05-14-2013, 11:37 PM
  3. Replies: 10
    Last Post: 07-03-2012, 04:33 PM
  4. John Deere 790 and John Deere MX5 Will it Work?
    By TerryWorkman in forum John Deere Owning/Operating
    Last Post: 02-13-2005, 03:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
