Results 1 to 7 of 7
  1. #1
    New Member
    Join Date
    May 2013
    Posts
    4
    Fosston, MN
    John Deere 60
    Default Powr-Trol won't hold rockshaft up
    I have a 1952 JD 60. The Powr-Trol lifts the rockshaft fine (I have a 3point on it with no implement attached) but it will not hold it up. It begins to go down immediately and is completely down in about 3 minutes. Any idea of what is wrong & what I need to do to fix it. I do have the dummy plugs in.
  2. #2
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,090
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Default Re: Powr-Trol won't hold rockshaft up
    It could the piston seal(A4464R & A4496R) leaking or this gasket(parts key #35 A1447R) has been known to blow.
    Attached Thumbnails Attached Thumbnails Powr-Trol won't hold rockshaft up-capture-jpg   Powr-Trol won't hold rockshaft up-capture-jpg
  3. #3
    Join Date
    Oct 2012
    Posts
    131
    Windham
    John Deere 70
    More than likely it is the seal but before you tear it apart, at the bottom of the valve housing there is an adjustment.It is the fast drop or throttle valve,take the hex cap off turn adjustment out till no tension then see if rockshaft drops.Yes? you need new piston O-Ring seal.
  4. #4
    New Member
    Join Date
    May 2013
    Posts
    4
    Fosston, MN
    John Deere 60
    Thanks, but when I took the hex cap off, there was no adjustment underneath to turn out. What does it look like; is it just under the hex cap? It could be that the previous owner removed something, as I found out the 2 gears in the pump had been removed. Any clarification of what it looks like will be appreciated. Terry N
  5. #5
    Join Date
    Jan 2007
    Posts
    7,090
    Coyote Flats,Tx
    Quote Originally Posted by Terry N View Post
    Parts key #52 in 1st photo.
  6. #6
    New Member
    Join Date
    Oct 2013
    Posts
    1
    Nemidji, MN
    JD 80
    Ive had similar problems, though mine has blown out the top of the gasket just above the round hole for the down speed valve. any thoughts other than maybe a stuck relief valve?
    Thanks
    Jim
  7. #7
    Join Date
    Oct 2012
    Posts
    131
    Windham
    John Deere 70
    The best way to fix the power-troll is pull it apart replace the O-ring make sure the gasket surfaces are square once back together adjust the up and down flow valves things should fine. All three of my last resto's 50,60,70 had that treatment with 100% success.
Similar Threads
  1. 58 john deere power-trol
    By terryb in forum Hydraulics
    Last Post: 08-22-2011, 11:17 PM
  2. JD eHydro vs Powr reverser
    By berobert in forum John Deere Buying/Pricing
    Last Post: 05-06-2010, 05:01 PM
  3. powr reverser vs e-hydro
    By ebeb in forum John Deere Owning/Operating
    Last Post: 04-26-2004, 07:02 AM
  4. '48 JD A Powr-Trol inoperative
    By BarryinMN in forum John Deere Owning/Operating
    Last Post: 08-30-2003, 09:31 PM
  5. now i are a powr trak guy!
    By Kaon99 in forum Power Trac
    Last Post: 12-29-2002, 01:40 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
