Results 1 to 7 of 7
  1. #1
    New Member
    Join Date
    Jun 2013
    Posts
    3
    Bath mi
    JD 140H3
    Default New to me 69 140
    Hi , this is my first post . I just bought a 140h3 at a yard sale
    a few weeks ago . Just started going through things it seem to be
    in good running condition . I got a tiller , snowblower , blade , three
    point hitch and a 48" deck.
    I changed the oil and the transmission oil today
    my concern with the trany oil is it took for ever to fill
    I looked for a vent but can't seem to find it .
    Any help to find it would be appreciated.
    Thx SteveNew to me 69 140-image-jpg
  2. #2
    New Member
    Join Date
    Jun 2013
    Posts
    3
    Bath mi
    JD 140H3
    Default Re: New to me 69 140
    Wow 115 views and no one has any old 140's
    that has any experience advise on the transmision oil change.
    Thanks for looking though.
  3. #3
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    to TBN
    Murph
  4. #4
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,081
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    I looked in JDparts.com in parts cat #1245 for a 140 and found no breather on trans.
  5. #5
    New Member
    Join Date
    Jun 2013
    Posts
    3
    Bath mi
    JD 140H3
    Thx Jim , I looked and found same thing but the book I have said to make sure breather screen was clean
    Not sure what book# it is , but for 140's serial numbers under 22000
    Mine is 015829M
  6. #6
    Veteran Member Barryh's Avatar
    Join Date
    Jul 2005
    Posts
    1,409
    Harpers Ferry WV - Mountains of Shannondale
    Former owner of a P T -180 / Kubota BX-1500 .. A Craftsman Yard Tractor / John Deere 140 H-1 / Cub Cadet 108. And now ( Little Red ) a Power Trac 1425
    Hi Steve, I have an old 68 140 H1 that has been sitting under a tarp for about 6 years now. Uncovered it last weekend and she started right up where I drove it into the garage. I plan to take my time and slowly restore this grand old tractor and put it to work around my property. I just went through the hydraulic oil change myself yesterday. I put in low viscosity John Deere hyguard. although I think our transmissions are different Sunstrands. I found a tiny breather screen on mine right up from the bottom of the axle housing next to a drain plug which I don't think the H3 has. I also tried to clean it with solvent. I had the same problem as you. It took forever to get the fluid in after the first 2 quarts. I also tried popping the screen out to no avail. I don't have the correct manual for my tractor yet. Guessing our screens are plugged up, because the oil would bubble up and spit at me.. Anyway I need to order the right manuals for my tractor. The engine runs strong and does not smoke but does have a loud tap to it. I also have an old Cub Cadet 108 around the same year at my brother in-laws house. I gave it to him and he never used it. It has been sitting under his deck for the last 6 years. It has the larger Kohler 14 hp in it. I plan to haul it back over here as it has some interchangeable parts. I may even try an engine swap into the old Deere. Looking forward to some pictures and your ventures with the old 140. I plan to strip mine down and repaint it and plan to restore it slowly. Barry
    Attached Thumbnails Attached Thumbnails New to me 69 140-john-deere-project-007-jpg   New to me 69 140-john-deere-project-008-jpg   New to me 69 140-john-deere-project-012-jpg   New to me 69 140-john-deere-project-006-jpg
    Barry
    __________________________________________________ _____
  7. #7
    Platinum Member corey9212's Avatar
    Join Date
    May 2010
    Posts
    740
    Red Deer County, AB
    2015 John Deere 3046R
    Default
    I had a 140 H3, that is one powerful little beast. I always said it was John Deere's attempt to take a big tractor and shrink it keeping the power of the big one. Of all my previous tractors I miss that one the most, the camshaft shattered while I was snow blowing a 5' drift.
    There is a breather screen I'm just trying to remember where it is (I have the original owners manual that I will check next time I go out to the garage.)
    Attached Thumbnails Attached Thumbnails New to me 69 140-image-1692606125-jpg   New to me 69 140-image-336330229-jpg   New to me 69 140-image-2579188521-jpg
    - 2015 John Deere 3046R
    - H165 Front End Loader w/73" HD bucket
    - 72D Auto Connect MMM, John Deere 375A Backhoe w/18" bucket, John Deere 59" Front Mount Snowblower, Frontier DH1296 8' Disc Harrow, Frontier SS2067B Poly Broadcast Spreader, Frontier AP12F Pallet Forks, John Deere 3PT Trailer Mover, Maybridge 12' Drag Harrow, 55 Gallon Spraytech 3PH Sprayer, 90 Gallon Water Carrier, 3 point bale spear
Similar Threads
  1. Farmall 140 with stuck ring(s)?
    By Ted Summey in forum Farmall Vintage Tractors
    Last Post: 06-12-2013, 11:33 AM
  2. Need Wiring Diagram for 1976 Farmall 140
    By N4WJT in forum Parts/Repairs
    Last Post: 06-07-2013, 11:36 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
