Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    May 2012
    Posts
    11
    Shelton Ne
    John Deere Model A
    Default
    I'm having trouble with hydraulic fluid leaking past the PTO shaft into the transmission. I have replaced shaft as well as the rubber seals and spring. Anybody have this trouble and find a better solution? Sorry it is a 1952
  2. #2
    Elite Member
    Join Date
    Sep 2010
    Posts
    4,100
    CANADA
    Many
    Default Re: 1953 John Deere A
    Did you install the seal backwards? I have seen a seal installed backwards on a Farmall cub on the rear main seal causing it to leak oil into the clutch housing.
  3. #3
    New Member
    Join Date
    May 2012
    Posts
    11
    Shelton Ne
    John Deere Model A
    Default
    Mike, I don't think I did all it is a two rubber o rings between two plates with tension on them by a spring
Similar Threads
  1. Replies: 4
    Last Post: 11-05-2013, 09:09 PM
  2. Replies: 10
    Last Post: 07-03-2012, 05:33 PM
  3. 1953 John Deere Model 40
    By Glassback in forum General Vintage Tractors
    Last Post: 02-07-2011, 06:48 PM
  4. 1953 John Deere Model 40
    By Glassback in forum John Deere Owning/Operating
    Last Post: 01-31-2011, 11:53 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
