Results 1 to 7 of 7
  1. #1
    New Member
    Join Date
    Sep 2013
    Posts
    4
    Hershey, PA
    John Deere 50
    Default 55 John Deere model 50 electrical issue
    I have a model Fifty with an electrical issue. There is a white (or faded yellow) wire from the ignition switch that goes to the regulator mounted on top of the Generator. The wire is 12 volts hot all the time, no matter if the main switch is on or off. This tractor will draw down a battery quickly when parked unless you unhook this white/yellow wire. Then, of course I am always re-equalizing the charging circuit or it won't charge while it's running. It can be started and operated with the wire off (no charging), and it will be fine as long as the battery is charged up.
    I cannot find an accurate schematic with the internals of the ignition switch, but I am leaning toward this piece being my problem. Otherwise, the volt regulator is to blame with a sticking set of points in it, but I HIGHLY doubt that there is supposed to be 12 volts hot on it all the time.
    Anyone?
  2. #2
    Platinum Member travlitt's Avatar
    Join Date
    Jun 2012
    Posts
    620
    Texas
    8050C Branson, Branson 2400 8N Ford Round Fender John Deere 110 3 60" ZTR mowers, a bunch of ride on mowers 8' Brush hog 15' Bat wing
    Default Re: 55 John Deere model 50 electrical issue
  3. #3
    New Member
    Join Date
    Sep 2013
    Posts
    4
    Hershey, PA
    John Deere 50
    Thanks. That does show the connections, but it the white wire at the volt regulator/generator hot all the time?
  4. #4
    Join Date
    Jun 2012
    Posts
    620
    Texas
    I don't know..Can you trace it to and through the initiation switch..That would tell you when it should be "Hot"
  5. #5
    New Member
    Join Date
    Sep 2013
    Posts
    4
    Hershey, PA
    John Deere 50
    I am hoping someone can tell me that's the way it's supposed to be or not. A schematic and not just a wiring diagram might show if the wires are connected all the time or connected with contacts inside the switch.
  6. #6
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,181
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Quote Originally Posted by Flashy65 View Post
    Yes white wire a regulator will have electricity as long as battery has voltage if amp meter doesn't have an open. I'll bet the regulator is the elect. drain.
  7. #7
    New Member
    Join Date
    Sep 2013
    Posts
    4
    Hershey, PA
    John Deere 50
    OK, thank you.
Similar Threads
  1. John Deere 850 electrical mystery
    By RickCowan in forum Parts/Repairs
    Last Post: 06-13-2014, 06:22 PM
  2. Replies: 10
    Last Post: 05-29-2013, 08:36 PM
  3. John Deere 214 Cranks up but wont run, electrical issue
    By noguice in forum John Deere Lawn & Garden
    Last Post: 04-29-2012, 10:51 PM
  4. John Deere 112 Electrical??
    By John Deere 110 in forum John Deere Lawn & Garden
    Last Post: 08-14-2010, 11:24 PM
  5. John Deere 66 electrical problems
    By rakos in forum John Deere Lawn & Garden
    Last Post: 08-09-2010, 07:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
