Hello all. First post to the forums.
I recently bought a 1958 JD 630. Owning my own tractor (specifically a two-cylinder Deere) has been a lifelong dream since I learned to drive my grandpa's JD 70. Now starts the learning. =)
It started and ran fine when I drove it home and the first couple times I ran it after that. Then one time I shut it down and when I went to restart it, nothing. The starter wouldn't turn over, the lights wouldn't work, there was just no electricity at all. I took the two batteries out and took them to O'Reilly. They put the batteries on their charger and tested them. They said they both tested good.
I took them back and put them back in the tractor and it started right off and ran well again for a couple times over a week or two. Then last week I went to start it and and the starter turned, but didn't turn the engine over. I tried it again and it could only muster a click. Tried it again and nothing. The switch is not getting left on.
I do not know enough about 12v systems or electric systems in general to troubleshoot this effectively, so I'd appreciate some help. Is there anything that could cause the symptoms I've described other than a bad battery (or two)? I don't mind buying a new battery, I just don't want to do that if whatever is causing this problem will just drain the new battery too.
Let me know if there is other information I need to gather to help diagnose the problem. Thanks.
