Results 1 to 10 of 10
  1. #1
    New Member
    Join Date
    May 2014
    Posts
    16
    procious, wv
    john deere 755 and 1530
    Default 1530 to much play in steering
    I just purchased a 1530 and there seems to be a lot of play in steering shaft. The steering wheel screws up and down an inch or two before the wheels start to turn. Is there an adjustment for this or is it just wear in the steering box?
  2. #2
    Elite Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    4,389
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Default Re: 1530 to much play in steering
    Remove rear inspection plug in clutch housing and check tightness of the bolt(parts key 12). Also check bellcrank(parts key 1) for loose brgs under center of frt axle & drag-link(parts key 10) tie rod ends.
    Attached Thumbnails Attached Thumbnails -rxp8590________un01jan94-gif   -rwp4498________un01jan94-gif
  3. #3
    New Member
    Join Date
    May 2014
    Posts
    16
    procious, wv
    The steering box #3 was just replaced on the tractor to fix another problem. (Used part). The play seems to to been in box #3. The steering wheel actually screws up and down before part # 14 moves
  4. #4
    Join Date
    Jan 2007
    Posts
    4,389
    Coyote Flats,Tx
    Quote Originally Posted by wrangler95 View Post
    Is slack still there with engine running?
  5. #5
    Elite Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    2,951
    South West MI
    John Deere 2030, John Deere 6415
    I am not sure what is normal. I have a 2030 and I think mine has even more play than yours, but it's 40 years old and it was 20 years old when I got it. At the slow speeds I use mine I do not notice it (most likely used to it) Only when I "road" mine, 8th gear 2500rpm it's a problem. It wants to wander a lot. Also if I hit a hole or bump it will sometimes go into a bad wobble, the front wheels moving back and forth real fast at maybe a 5-10 degree angle. I think the wobble is the bellcrank bearings (#3 in drawing two posted by TxJim). The play I suspect is the column needs to be rebuilt (in my case), but not until it fails.
    I will check how much play mine has next time I use it.
    John Deere 2030 JD 245SL Loader
    John Deere 6415 mfwd JD 640SL Loader
  6. #6
    New Member
    Join Date
    May 2014
    Posts
    16
    procious, wv
    Quote Originally Posted by Zebrafive View Post
    Thanks it does sound like similar problem
  7. #7
    New Member
    Join Date
    May 2014
    Posts
    16
    procious, wv
    yes slack is still there with engine running
  8. #8
    Join Date
    Aug 2010
    Posts
    2,951
    South West MI
    My 2030 has about two inches of steering wheel play. I only really notice on the road at speed. My guess is the steering column/valve is worn, maybe leaking internally?
  9. #9
    New Member
    Join Date
    May 2014
    Posts
    16
    procious, wv
    Is it it possible to rebuild the steering valve. The one that was taken off the tractor would turn left OK but had no power steering when turning right. When sitting still
  10. #10
    Join Date
    Jan 2007
    Posts
    4,389
    Coyote Flats,Tx
    Yes although shimming the inside control valve is tricky the complete assembly can be rebuilt. Your valve assembly probably had something worn in parts key 23.
    Attached Thumbnails Attached Thumbnails -rxp8388________un18aug95-gif
Similar Threads
  1. Steering wheel play
    By Cbrown9064 in forum Ford Vintage Tractors
    Last Post: 05-17-2014, 05:05 PM
  2. JD 420 Steering Play
    By OutbackL130 in forum John Deere Lawn & Garden
    Last Post: 08-24-2013, 08:30 PM
  3. 1530 power steering
    By tonyopitz in forum John Deere Owning/Operating
    Last Post: 02-20-2012, 01:08 PM
  4. steering play on t1770
    By andyt11 in forum Kubota Lawn & Garden
    Last Post: 10-12-2011, 10:41 AM
  5. play in steering - 1500D
    By tmoritz in forum Yanmar
    Last Post: 07-24-2007, 10:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2014 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
