dvaidm
Member
Doing some maintenance on the 3020 john deere it is gas. Where is the fuel filter located at. I am going to replace the plugs and wires and cap and rotor does it have points. Any other recommendations I should do.
:welcome: to TBN
Fuel filter located right side of engine. part # AR50141 (follow fuel line from the carb).
Yes, has points.
The part number AR50141 is an incorrect number. Gasoline filter is AR10104 if tractor is equipped with a MS carb or AR13019 with a Zenith carb.
AR50141 is correct for serial numbers above 123,000. Earlier tractors did not have in-line filter. Only a strainer in the inlet fitting to carb.
