kenknox
- Joined
- Oct 22, 2014
- Messages
- 4
- Location
- brooklyn, ia
- Tractor
- 1944 John Deere D, 1948 John Deere B, 1967 John Deere 110, 1946 Farmall H, 1935 Farmall F-20
I just replaced all the bearings in my 48 JD b transmission. When I removed the belt pulley and clutch assembly it came off very easy. I replaced the pulley,inner facing and driving disc on the shaft. I aligned the timing marks. The pulley pushed on by hand leaving approximately 3/4 inch to go before it was flush with the shaft. The service manual says to draw the cap screw up as tight as possible. I was assuming this would pull it up flush with the shaft but it didnt. Its around 1/2 inch from flush. The manual dosnt specify if it is suppose to be flush or not. Before I continue with assembly I need to know what is correct (Flush or not). Can anyone help me?
Thanks
Ken
Thanks
Ken
