I found this 74 JD with kohler K241 in old barn at sons new property owner said he could have it hasn't been running in over 20 yrs. loaded up took home started with basics getting it to turn over after soaking piston as it was with marvel mystery oil cleaning off valve cover an basic cleaning found froze up exhaust valve got that cleaned and set, found the safety button on neutral was causing no fire to starter fixed that dumped gas tank cleaned rebuilt carb every thing back together took out blocked froze fuel pump blocked it off, ready for first try amazing it fired and ran the starter fluid out excited I ran got phone videoed the same thing it cranked right up burned out starter now to make a makeshift gravity feed gas tank I filled bowl quick shot and nothing since then I get nothing, I've got a spark check and with it not connected to plug it shows hot fire from coil with it to plug light not much I bought new plug same thing. I want to check points condenser but cant get the fan housing off with the frame lie it is made kinda impossiable unless I take motor out unless there is a trick???? that's question number one next question why am I showing such a hot spark if coil is bad I get 12v on both post with key on would that completely rule out coil and new plug what are the chances I got a bad one ? would like some help trying to figure this one out I don't want to buy a lot of stuff to fix I up if im sinking alot into motor Thanks a lot Mitch
