Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Gold Member
    Join Date
    Apr 2014
    Posts
    482
    Logan, WV
    JD 650, Ventrac 4500Z AJ02248
    Default I wonder if my glow plug or pre-heat system is really working.
    My 33 year-old JD 650 just keeps on keeping on. In the distant past I was able to hear a little "pop" in the manifold when the glow plug activated some fuel, but past few years that "pop" has been absent. So, in beginning my winter prep yesterday ahead of snow season, I decided to trouble shoot it. I grounded my volt meter, but the positive probe on the plugs connecter and turned the ignition switch to pre-heat position. I got full battery voltage reading at first (13.35V) and that voltage dropped rather quickly as I continued to hold the switch closed for 45 seconds (12.2). So I reckon the plug is drawing a good bit of current, but still no "pop". It was not very cold yesterday, upper 30sF as I was testing. I got on the tractor and cycled the glow plug again and started the tractor. It fired right up, but that tractor almost always fires right up without the plug assist unless it is in the 20sF. So I wonder if the pre-heater fuel feed to the manifold is working and how to check it or service it.
    prs
  2. #2
    Gold Member farmeratheart's Avatar
    Join Date
    Aug 2008
    Posts
    371
    MD & Adirondack Mtns
    JD2520, JD650
    Default Re: I wonder if my glow plug or pre-heat system is really working.
    prs,
    I'll be watching this thread with interest. This summer I picked up this 1985 JD650 to use fall and spring moving boats around our storage barn. The temperature of the morning that the attached picture was taken was 24F. The tractor started right up after cycling the glow plug/fuel burn system. It ran rough for a bit, but ironed out OK. I'm real happy with this tractor and hope to give it another 20 or 30 years of use! I would like to know if the system is working properly.
    Frank
    I wonder if my glow plug or pre-heat system is really working.-jd650-work-jpg
  3. #3
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    26,898
    Branson, Mo.
    Kioti DK35se Hydrostat
    There are several way to determine if the glow plugs are drawing current. I have a simple inductive coupled current meter I would place over the wire feeding the glow plugs and measure the current that way. You could use a thermal heat sensor gun to measure the temp rise on each glow plug. You could measure the voltage on the glow plug rail, then if you remove the rail and do a resistance check of each glow plug to the engine block you could be pretty assured that they are working.
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN .
  4. #4
    Join Date
    Aug 2008
    Posts
    371
    JD2520, JD650
    James,
    I think PRS is pretty confident that current is being used by the glow plug of the "Thermo start system" (I think that is what it was called in the 1985 Owner's Manual for the JD650), but he is unsure if the small amount of diesel fuel is being ignited at the manifold to warm the components. My manual is put away at our camp for the winter- I won't be able to check it until the spring. However, I was also wondering how to check the fuel part of this older system?
    Thanks.
    Frank
  5. #5
    Join Date
    Jun 2009
    Posts
    26,898
    Branson, Mo.
    Quote Originally Posted by farmeratheart View Post
    James,
    Thanks.
    Frank
    Aha, I see that now that you mention it.
    James K0UA
  6. #6
    Join Date
    Aug 2008
    Posts
    371
    JD2520, JD650
    Quote Originally Posted by prs View Post
    My 33 year-old JD 650 just keeps on keeping on. In the distant past I was able to hear a little "pop" in the manifold when the glow plug activated some fuel, but past few years that "pop" has been absent. So, in beginning my winter prep yesterday ahead of snow season, I decided to trouble shoot it. I grounded my volt meter, but the positive probe on the plugs connecter and turned the ignition switch to pre-heat position. I got full battery voltage reading at first (13.35V) and that voltage dropped rather quickly as I continued to hold the switch closed for 45 seconds (12.2). So I reckon the plug is drawing a good bit of current, but still no "pop". It was not very cold yesterday, upper 30sF as I was testing. I got on the tractor and cycled the glow plug again and started the tractor. It fired right up, but that tractor almost always fires right up without the plug assist unless it is in the 20sF. So I wonder if the pre-heater fuel feed to the manifold is working and how to check it or service it. prs
    Hey PRS,
    Look what I found on YouTube !!!
    www.youtube.com/watch?v=Wi4mV8nrfz4
    A demonstration of a working Thermostart system.
    Frank
  7. #7
    Join Date
    May 2013
    Posts
    856
    Norway
    Mf135, Ursus C-355, David Brown 995
    Default
    Loosen the pipe and there should be diesel comming out.
    Quite common that the smal tank or pipes needs to be cleaned, if you have diesel and heath you might have a bad thermostart unit.
  8. #8
    Gold Member
    Join Date
    Apr 2014
    Posts
    482
    Logan, WV
    Hey PRS,
    Frank
    Well, who would have thunk it! Now you have heard that little "pop" noise I used to hear. I will try to replicate the video.
    Quote Originally Posted by Agvg View Post
    Well a big HELLO to Newfoundland! My top tank looks as clean as new with its bright red diesel. I have been thinking that the pipe or opening device might be clogged. I will investigate that if I can not duplicate the video. We are having an indian summer here and instead of working on tractors, looks like I am going to have to mow the fields again! In November no less! This time last year we had already had several snows. But, the reprieve from winter will not last and I will be in the shop again.
    prs
  9. #9
    Gold Member
    Join Date
    Apr 2014
    Posts
    482
    Logan, WV
    I "think" the JD part #CH15593 is the same as the Yanmar ThermoStart unit for Model 1110D which is available for $20.00 US delivered on eBay and elsewhere. So, if mine is broken beyond recovery, I can still get back to hearing that little "pop". Life is good!
    prs
  10. #10
    Join Date
    Aug 2008
    Posts
    371
    JD2520, JD650
    prs
    Please let us know how it works out. I will file this away for use next spring when I am near the tractor again. Don't you just love this forum?
    Frank
Similar Threads
  1. Kubota L3010 glow plug indictor not working
    By bribo54 in forum Parts/Repairs
    Last Post: 12-30-2013, 02:46 PM
  2. Oil & Fuel One Glow Plug working?
    By eightksi in forum Mitsubishi/Satoh
    Last Post: 09-29-2010, 10:10 PM
  3. Fuel HEAT glow light is no longer working
    By frankbellamy in forum Mitsubishi/Satoh
    Last Post: 08-28-2010, 11:38 PM
  4. Glow Plug and fuse system
    By mffarmall in forum Chinese Tractors
    Last Post: 11-08-2009, 09:18 PM
  5. MT20D glow plug system?
    By Rebeldad1 in forum Mitsubishi/Satoh
    Last Post: 09-21-2009, 10:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
