mrrog
Member
Here's one for you JD gurus out there. I just bought an '85 650. A nice clean old tractor with all original paint. (no cracked or repainted welds). It does sound like a bucket of bolts while running. But I assume that it just sounds like a two cylinder diesel. After bringing the baby home I realized the oil pressure and water temp lights were not working. Only the battery charging idiot light is working. I hate to put it to work without knowing that these other two systems are good to go. I figured on just changing the bulbs but it looks like I'm going to have to dis-assemble the whole dash and gas tank cowling assembly to get at the bulbs. It also has a herd top cabin. There is an inspection plate under the steering wheel but it doesn't seem to give me access to the bulbs. Anyone got a clue?? The dash panel is black plastic but I don't think that it would be wise to try to pry it up to allow access. Or does it sound like a sending unit failure? Thanks for reading my inquiry.
