Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    New Member
    Join Date
    Dec 2017
    Posts
    12
    Fitzwilliam NH
    JD 400 Industrial
    Default Re: Starter keeps cranking
    Yes. Sorry. I was checking the continuity on the switch. The switch checked out ok.
  2. #12
    New Member
    Join Date
    Dec 2017
    Posts
    12
    Fitzwilliam NH
    JD 400 Industrial
    Quote Originally Posted by beenthere View Post
    That wasn't much of a surprise..
    I have put a new solenoid on it and it still does it. I am leaning towards the batteries are junk. Not holding enough amps. I am gonna try new batteries this week when it warms up and the fuel filter and pump can de-jell.
  3. #13
    Gold Member LouNY's Avatar
    Join Date
    Jul 2015
    Posts
    435
    Greenwich, NY
    Branson 8050, IH 574, Oliver 1550 Diesel Utility
    Quote Originally Posted by 70jd400 View Post
    Before you buy batteries, can you disconnect all the wiring off your starter but the battery cable, and then after blocking the wheels and double verifying that its in neutral jump from the starter battery post to the solenoid switch terminal to see if it behaves normally then.
  4. #14
    Veteran Member K7LN's Avatar
    Join Date
    Feb 2009
    Posts
    1,672
    Michigan
    JD455 & JD790
    Now that makes absolutely no sense whatsoever! Follow post #13 and report back the results.
    It will show that you either have a mechanical problem or an electrical problem.
    JD 790 w/70 FEL & 7 BH on turf tires
    JD 455 w/60" MMM & 54" front blade
  5. #15
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,052
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    I have witnessed where low battery voltage caused solenoid internal washer to stick to studs more especially on 24 volt starters.
  6. #16
    New Member
    Join Date
    Dec 2017
    Posts
    12
    Fitzwilliam NH
    JD 400 Industrial
    Quote Originally Posted by Tx Jim View Post
    A few days ago I tried to start it after charging the batteries and everything was good the solenoid acted as it should (start let go of key and starter disengages). I took a while to start because there was some jelling going on. Once it died I tried to start it again and the starter stayed on would not turn off until i disconnected the batteries.
    Later on this week when it warms up above 30 and the lines de-jell i will try it again with a full charge on the original batteries and if that doesnt work than i will try jumping at the solenoid as stated in post #13.
  7. #17
    Join Date
    Jan 2018
    Posts
    89
    Belfast, Maine
    Kubota L2500
    You have a low voltage problem.
    I had the same thing on my John Deere 350D and it took awhile to find too, so don't feel too bad. I always start with the easiest and the least expensive things to check first. Here is a short list...
    1. Check to make sure the positive lead wire is not chaffed and shorting out on the chassis somewhere robbing your starter of voltage
    2. Check batteries
    3. Check negative battery terminals for contacts on chassis
    4. If you have a spare battery cable, try attaching it from starter to chassis, sometimes a starter does not get a good ground through the chassis due to oil and paint, etc
    5. But, you said the tractor is industrial. I wonder if it has a battery disconnect switch? If it does, that is most likely your culprit. That is NOT a knife switch, it has contacts that as you move the lever, it brings power upwards and into contacts. These arc out over time and cause low voltage problems. It took me awhile to find that issue on my tractor.
    It is best to put the disconnect switch on the negative side of the batteries, but is not always easy to do. It does however prevent arcing inside the switch.
  8. #18
    New Member
    Join Date
    Dec 2017
    Posts
    12
    Fitzwilliam NH
    JD 400 Industrial
    Ok. So i took the starter out and took it to a garage that my wife works at and one of the techs there bench tested it. He said the starter is fine and he be leaves that my problem is the spacer and the tip of the starter is no longer sitting in the grove witch is letting the gear over through the flywheel and the starter gear is becoming hung up and not retracting. So i have ordered the new spacer for $9. Just waiting on parts to come in. I ordered #'s 6,7,8
    Starter keeps cranking-starter-parts-diagram-png
Similar Threads
  1. Replies: 9
    Last Post: 01-25-2015, 10:02 PM
  2. Starter solenoid clicks a few times before cranking
    By Ed in Maine in forum Cub Cadet Tractors
    Last Post: 12-20-2013, 04:06 PM
  3. Starter keeps cranking ???
    By Richard in forum Parts/Repairs
    Last Post: 02-03-2011, 09:21 PM
  4. Non cranking
    By MSman in forum Cub Cadet Tractors
    Last Post: 06-24-2008, 01:38 PM
  5. Cranking up the Hp?
    By Jarring2 in forum Kubota Buying/Pricing
    Last Post: 05-23-2001, 12:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
